mal's ozzie S1E2
thanks ian, yes ive been mindfull of the balance and iam hoping by keeping the nose up it should help. All the old vids you see they look like boats(nose up ) under accelaration and besides the roads here arent great so it might help to save the front apron. I will be using custom MCA struts which are as good if not better than proflex in my opinion so adjustment will be avaliable.
one thing i do need is a app weight for the axles as a starting point?? anyone help, even the factory weights of a sport would help.
thanks
malComment
the wheels in the first photo of the thread are the 18" team dynamic wheels which the car came with, the other shot shows geniue works gravel wheels. There the stupid 390mm/15.5" ones.Iam going to run A4/A6 5 spoke 15" wheels for the moment but ive been looking for a rep of the works ones but cant find any. Ive looked into getting some made but it will have to be later as iam hoping to have a drive later in the year. After that ill look at it more
thanks
malComment
ok starting the assembly work now and ive got some questions , having never seen one put together i was hoping someone would have some photos showing 034 motorsport spec engine mounts and gearbox mounts fitted . do the gearbox mounts go under or ontop of crossmember , same goes for the diff mounts
anyone????
thanks
malLast edited by malncol; 30 June 2013, 10:48.Comment
But I think they're mounted on the underside of the subframes.
