From Audi 100 to urS4 in a week
  • ringbearer
    replied
    I had a chunk on cat stuck in the last bend of the muffler. Remove the exhaust from the cats back and test it out.
  • hunker7
    replied
    Unfortunately car isn't still pulling well, the same issue with the revs not going over 5k. Car runs better generally but it's just when you get to high revs/speed.
    MFTS seems to be playing up, as sometimes it works sometimes it doesn't, but MFTS isn't the one giving ECU the info is it? I've ordered a new lambda sensor, as I couldn't find any records of that being changed and car has done over 180 000 miles. Fuel consumption is bad too, regardless of how I drive 16mpg is the best I can do around town.
    Can exhaust be blocked anywhere else apart from catalysts and middle silencer?
  • hunker7
    replied
    Originally posted by UrS4boy
    Just to you know, when the 1.8t coil pack failures first started to show up, it was Bremi who had made the defective coils. If I remember correctly the VAG folks held Bremi's feet to the fire and made Bremi re-supply new coils to VAG at no cost to VAG. (But that is from memory, going back to 2004/05).
    These are from V8, and also, i hope they learned from their mistakes
    replied
  • hunker7
    replied
    Good news! (for once)
    Runs much much better with the fuel line sorted now. Goes over 4k in 5th easy, but need someone who knows these cars to drive it, to tell me if it's running 100%, but it's good for now
    Didn't like the way car was on idle, so got set of new coil to trial and it's much better, so I'll send the used ones back.
    On top of that, got a quote from LongLife for exhaust, £450+VAT for decat, downpipe onwards. Sure they sent me a picture of the S6 Plus Spink was breaking
  • hunker7
    replied
    After some time managed to sort the fuel pipe the, wish me luck
    I had a suspicion that compression is low (9 bar) because of bad starter motor, but I started the car on 4 cylinders and it's still low. So, I put some oil in the cylinder and compression went up by 2 bar. So I have no choice but to open up engine over summer and do the shells and rings, and hopefully upgrade rods as I am planning on many torques in next couple of years.
    replied
    G61/G66 Knock Sensor Information
    Originally posted by hunker7
    Might be a daft question, but how does the engine know that's it "knock"?
    Piezoelectric signal(s) from the G61 and G66 knock sensors
    G61 and G66 Knock Sensor Info:
  • hunker7
    replied
    Originally posted by newsh
    It will go lean, knock and the ecu will retard ignition and try to add more fuel, it will basically just hold back.
    You're blessed that it is as 'simple' as this, the car should be much improved once you resolve this.
    Looking forward to your post after it's fixed.
    I am now trying to figure out how to sort it tomorrow.
    replied
    *DING*
    Perfect diagnosis.
    replied
    replied
  • hunker7
    replied
    Thanks, I'll see what I can do why doesn't it shake when there isn't enough fuel?
    replied
    Not f'ed up completely. It is twisted though. ill see if I can get it sorted 17mm socket was involved because I was trying to take it apart,unsuccessfully.
    NO. It is completely Fk'd man. This is your problem: fuel restriction under high demand.
    Re-check my post. I edited it to include a photo and a link.
  • hunker7
    replied
    replied
    C4 UrS Fuel System: From the Tank to Injectors and Back Again
    If there was a fuel deficit wouldn't there be shaking when there isn't enough? Only thing is this that I noticed couple of days ago, the inlet pipe is squashed
    Twisted? Mangled? Fk'd up behond all recognition (Fubar'd)?
    The good news is you have found your problem.
    The bad news is you have to fix it. (and you need that double-flared end). Why is a 17 mm socket involved?
    C4 UrS Fuel System: From the Tank to Injectors and Back Again:
