Audi S1.5 [OEM+] - (10-valve turbo B3 Coupé)
So yeah, I got a hold of a 7A flywheel and clutch, but the seller wasn't... Let's say thoughtful...
TOP RIGHT
CLOSE UP
Some sort of preassure plate line-up pin I guess?
Still usable I hope, I can't see why not as long as I get the PP on correctly?
doesn't matter.. these are only the pins for ignition check.. 12 degrees and 15 degrees i think.. you don't need them.. important pin is at engine side.. 62 degrees before TDC1990 Audi 100 2.2 Turbo Quattro with VEMS, K24 2480, ported and milled 10v headComment
you mean the 62 degree before TDC? should be always the same on every flywheel.. therefore you can only mount it one way
Spin baby, spin!
After a lot of faffing about we're finally back in the garage. The gearbox-debacle really put a twist on things and took some figuring out, but now we have some wind in our sails again!
A big thanks to everyone with more knowledge than me on this subject, it really helped!
Sadly the battery in the camera was dead, so I only took a couple of quick cell-photos this weekend, but maybe I can share a few pics during the week and remember to charge the camera 'til next time
Without further adieu;
A quick wash
A too fimilliar sight! But I'm now blistering fast at pulling the engine
Removed the old box and mounted the flywheel/clutch. The 7A stuff was easily twice as heavy as the old MC stuff which had a super thin flywheel...
"new" box mounted, hopefully it doesn't fall apart
Aaaand back down again. A nice side-effect of the the "new" box is that I could use the old standard mount again, and it made the engine sit a little better
Big thanks to all who replayed with quick answers regarding this issue, always spot on!
Regarding the flywheel line-up misshap we had.
I don't even know how we pulled it off, but somehow we couldn't get the timing-pins to be in the same place even thou you can only fit the flywheel one way. I have no idea how but all of a sudden the stars aligned and there it was, no problem. We must have had a complete brainfart and overlooked something...
Next up on the list, testfire the engine again to verify that all is in order, connect the shifter and clutch pedal so I can test the clutch, hook up some driveshafts, and then I need to figure out a gaswire and the intercooler...
I have some idéas, but I'm not 100% happy with them, so suggestions are welcome
Does anyone know what wire goes where on the RED connector on the MC-harness?
The thick BLACK one is for the idle-valve
I have a BLUE/BLACK and a RED/BLACK on +12, no idea what they do and can't find any good info.
Then i have 3 or 4 BROWN with different colored stripes that I GROUND, except one which is the fuelpump-signal.
I tried too tidy up some cables while I was waiting for the flywheel, and now the engine won't fire
I thought that if I knew what they did it I could maybe see the problem without cutting of my new pretty connectors and testing the wires one by one
never heard of that ... got some part numbers??
