Projekt Alpinweiss V - Rebuilding the new engine...
    Daily commute in to the centre of Bristol and back done. Didn't miss a beat, except at idle, where the lightweight flywheel has made it a little less smooth than Audi intended. Clutch was perfecly manageable and the brakes too. Temps never went over or under the ideal position and the oil pressure was 2-5 bar.
    • LucheS2@20v
      Banned
      • Nov 2015
      • 115
      • Country: Bulgaria
      #107
      Lovely clean engine bay. Post you photo in engine bay thread
        Warwick and back today, taking in some nice roads over the Cotswolds
        275 miles so far so it's time for another change. No issues other than the severity of the vibration at about 1800 rpm on occasion. Waiting until the engine and gearbox mounts are sorted as the engine mounts aren't the best. Need a second opinion at some point.
          500 mile running in period they said...
          New oil fitted, N75 plugged back in... took a brave pill and went for a run. Oh how I'd missed that feeling and with the valve open I had a tear in my eye (naturally because the window was open and nothing to do with my 3 months' hard work to get this done)
            Well done mate, now enjoy your hard work
              Nice one!
              Any news on the vibes at 1800 rpm?
                It still chatters a bit but will see how it goes. Engine mounts are shot so once they're replaced, things will be different, if not better...
                  or worse!
                    Indeed.
                    Got a bit angsty about a chattering noise under the car... what could it be? Was it from the engine? Had something gone wrong?
                    No. It was the metal faced clutch release bearing. New clutch is lighter than expected and doesn't appear to slip, so happy with that.
                    Brakes are next on the list... never ends
                      Yes my metal faced bearing started chattering at idle after about 800 miles
                        The plastic faced Sachs item I took out after 15k miles was untouched by a stock clutch. At least the metal one looks very meaty
                          So 525 miles in just under a week and other than a small leak in the breather, all seems well and performance is definitely there The subtle changes to the head and inlet have freed up a bit of mid to top end and the lightweight innards have given a small increase in low gear pep
                          After chatting with JP, I may now be at the stage where it needs the map tweaking to take the better breathing in to account, so a new turbo is on the cards as there's no point custom tuning the RS2. Nothing mad, either 390-400 on a hybrid billet RS2 or 425-450 on a GTX3071, HX Super 40 or one of the KKK K26/27 billets that seem more readily available; either way it would need to be a K26 flanged turbo to work with my Wagner, unless I trade it in...
                          Just the question of who to map it... as ever
                          • Kieron20V
                            • Mar 2008
                            • 1505
                            #118
                            GTX. See if we can get a discount on buying 2.
                            Sent from apollo 13 using tapatalk
                            1994 URS4 Avant RS2+
                            • diesel des
                              • 3896
                              #119
                              The gtx3071r looks great on paper but from the results I have seen it seems to preform like an expensive gt30r. Not that that's bad but not the step forward it should be. No axe to grind just saying.
                              • SteveH
                                • 4460
                                Hx40 will be too large. For simplicity and reaching your 450 target without too much lag and ease of plumbing, I would go RS2 hybrid or 26/27. As you have an RS2 unit already, I would get it hybridised. Easy, chreap and bullet proof.
                                91 Modded 3B
                                14 A6 Avant Black Edition
