My sleeper
  • hammer
    • May 2008
    • 242
    • Country: Austria
    #121
    Her the Next one[emoji41] , i Hope the last[emoji16]
    • AndyP
      • 6049
      Originally posted by hammer
      2,5tdi and 81.5mm
      What engine code was it?
      • hammer
        • May 2008
        • 242
        • Country: Austria
        #123
        Aat
        • diesel des
          • 3896
          #124
          This must be a casting defect. Many people have went to upto 83mm without problem. Hope your next one is better. Have you thought about liners for the cylinder. Should be much stronger.
          Sent from my HTC Desire HD A9191 using Tapatalk 2
          • hammer
            • May 2008
            • 242
            • Country: Austria
            #125
            Yes i think about it. It were perfect with nikasil coating, for les friction[emoji57]
            • hammer
              • May 2008
              • 242
              • Country: Austria
              #126
              The pistonrings are good
              • hammer
                • May 2008
                • 242
                • Country: Austria
                #127
                Her two pics from the log
                • hammer
                  • May 2008
                  • 242
                  • Country: Austria
                  #128
                  During the First testdrive. So its not really good.
                  • hammer
                    • May 2008
                    • 242
                    • Country: Austria
                    #129
                    • hammer
                      • May 2008
                      • 242
                      • Country: Austria
                      #130
                      And some pics from the work one the New Block
                      Bypass for the oil from the overpressurevalve
                      • hammer
                        • May 2008
                        • 242
                        • Country: Austria
                        #131
                        Close the oilway from the pressure relief valve.
                        • hammer
                          • May 2008
                          • 242
                          • Country: Austria
                          #132
                          Also have to make New distances for my stiffening plate
                          • Wizard-of-OD
                            • 926
                            • Home: Syria Current: Canada
                            #133
                            Careful with these sensors. I am almost tempted to machine an impulse wheel that gets squeezed between the flywheel and the crankshaft hub
                            Issam N. Abed
                            iABED Industries
                            iABED Email | Facebook
                            The build thread
                            • hammer
                              • May 2008
                              • 242
                              • Country: Austria
                              #134
                              New oilpump befor and after
                              New rods and pistons. Rods have 159mm and 21 pin. The Wiseco Pistons are for a Honda b16, but they have perfect conditions for me. With 29.85mm cr high i get 9.5:1 cr-ratio and payed just 130,- for one.
                              And the pistons just ned 0.06mm clearance, the same like mahle
                              • hammer
                                • May 2008
                                • 242
                                • Country: Austria
                                #135
                                Mill the block
                                The end from the rods were to wide so i mill it
