Acuually, I do not see where I specified rotational or not. As I read it, my statements are accurate by virtue of vagueness
We are all wrong since the "torque limit" of the stock rods is backwards, as you pointed out. X psi of combustion is required for q NMs, so we can assume that a flawed tune caused too much cylinder psi or perhaps it was the result of increased boost and increased density. I would think the pistons would show signs of detonation.
Regardless, I was giving PRJ a hard time to lighten things up in here.
Nothing seams to be posted about this for a long time,just wondering what was the verdict.Did another get built with same hybrid and was it successful.As you put it if this turbo hybrid spooled up much quicker and had better torque figures than the standard Rs2 and given that its much cheaper than RS2 turbo and has no lag it would seam to me a bit of a no brainer.Have you or anyone else been successful with this turbo hybrid?? Cheers
