Volvo K24 turbo in audi application.
The volvo turbo has some kind of vband outlet
Does anybody have any simple home DIY ideas for getting a regular silicone coupler to attach?
Will the turbo "coldside" get too hot to JB weld a sleeve inside the outlet?
Failing that how hard is it to MIG weld a turbo coldside at home?
Or just cut off the vband and clamp on whats left?Current-2004 Impreza PPP wagon
Sold ABY-stockComment
yes the earlier models of this turbo had the v-band, later were "standard". My thoughts are you could grind it down and then fit over it, you could get the v-banded part and use the v-band hose and cut it off and use that pipe for your standard coupler.Comment
Thank you for the ideas gents
Why not? I know I would need wire, plastic liner, gas etc. Or would I just not be able to get enough heat into it?Current-2004 Impreza PPP wagon
[QUOTE=andy10v;599045] Why not? I know I would need wire, plastic liner, gas etc. Or would I just not be able to get enough heat into it?[/QUO
As you say welding alloy with a MIG is possiable with the correct wire, gas ect, however it's REALLY tricky and it will never be as tidy as TIG.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
you can do it with MIG, but for somethign like that it'd be really very very difficult IMHO. You need argon. The wire is really soft so you need a teflon liner to get a smooth feed, plus you want to use a large diameter wire which is stiffer to help with feed, but most DIY MIGs can't handle anything over 1.0mm. Ally conducts heat very quickly compared to steel so its hard to see the weld pool before it blows a big FO hole in the work. Then its a circular piece to weld which are tricky anyway!
Imola B6 S4 AvantComment
Just a little update, winter is here and temps have been considerably lower, and car has been running noticeably quicker as well... So much so that i put a window in my block:
I guess stock rods with 450ftlbs+ of tq at the crank is perhaps a bit much for them. I already have a set of DM forged rods and another block to throw them in, hopefully will have it up and running in the next couple weeks, then we can up the power a bit more and run some e85!Comment
That's not rods, that's knock.
Exactly what happens when you have no knock feedback at all and run too much timing/boost.
I have mapped 10+ cars now to run 450 ft lb on stock rods, oddly enough, none of them have problems
