You are comparing apple to oranges. What did a stock b7 rs4 pull on the same day as that AAN you posted? If you do not have a benchmark, they are just numbers.
As was said above, Dave got crazy torque because he gave it boost where he had turbo flow. If he ran *only* 14psi, his curves would look just like the rs2s.
The same story with my day at the dyno. I will post up on my own thread, but I basically came back to run the hta gt3582r at full tilt. I had made 520whp/460wtq a few months ago at around 29psi. At that level, I was able to hold 29psi to redline. The curves were fairly flat. This time around, I ran the turbo balls out, with the wastegate clamped shut(disconnected wg line). I hit 38 psi at torque peak of 5100, but was down to 32psi by 7500, and 29 by 8500. Well I made the same power at redline, but I now made 612whp/527wtq at the area where I had more flow.
