Volvo K24 turbo in audi application.
Because that compressor won't do more.
And a RS2 compressor will not do 380hp without heating the air like crazy on a stock engine.Comment
the volvo units have (IIRC) the same compressor impeller dimension but a more efficient design than the RS2. The RS2 turbo can do 380 without to heat the air like crazy and it is proven more than once in real life and in paper.Last edited by Billman; 18 July 2011, 09:29.Go Holset or Go RS4Comment
No, it's not "proven more than once".
Post some proof, IAT vs RPM vs Boost vs IDC for example.
And you know why? Because I have more than 300 of such graphs of the RS2 turbo.
I know perfectly when it starts heating air like crazy.
The Volvo turbo has a smaller compressor than the RS2, get your facts straight.Comment
In your experiance at what sort of power level does the RS2 compressor start to cause excessive inlet temps? 350BHP? I know there are variables like ambient air temps and intercooler size ect.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
sorry i dont longer have my logs from back then with the stock setup. post something of an rs2. Stock ADU engine/turbo/IC etc.No, it's not "proven more than once".
Appart from it i must apologize about the hp statement. The volvo unit has a smaller then RS2 impeller but better design. The rs2 has an 66/48 compressor impeller and the volvo as stated before with 62/46mm. That said the Porsche/volvo hybrid could at the best come close to the rs2 output.Go Holset or Go RS4Comment
I got another k26, this time with a 50mm exducer, beleived to be porsche, possibly a 944
Tag
Hotside
And the hotside on the volvo turbo
If the compressor is the limiting factor in this hybrid it doesn't seem to make sense to install a larger exhaust wheel for more flow, might as well get fast spool.Current-2004 Impreza PPP wagon
Sold ABY-stockComment
Andy, that is from a 944 turbo 220hp
. The part number can be checked here (unfortunately not the hotside part number, only the turbo one):
As it has been said before, your pictures confirm that the compressor housing fits perfect to the Volvo turbo.
I will follow this thread with lots of interest.
Cheers.Audi Coupé S2 '92 -- VW Golf 2 GTI '91 (v2) -- Renault 4 TL '84 -- Audi 100 2,3E '92 (Dad's) -- Suzuki SV 650 S '08
Numbers on hotside:
Inside is stamped "6".
Outside GGG3552
5326 101 6362EComment
K24-7400 vs K26/K27 #6
I went with the K26/K27.Comment
Sure, as long as your spring has not been wound down and other silly things.Comment
