Stroker build
Nope. 20VT with AAN intake manifold inside little chassis, T81, T85, T89 or B4, will not work with radiator at original place. You at least have to place the radiator angular, or change it to a smaller and deeper one. Or take another IM. If it is that, what you're meaning
it is possible but you need adapt some things
i have a typ85 with AAN 20vt and a big alu radiator on the same place
i modefied the AAN intake and the left chassis legaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
TWINCHARGED power,zero lag
AEM W/M injectionComment
what I see from photo typ85 has less space in engine bay than B4.
I don't see the need to modify intake, but regarding chassis leg it is interesting,
will see when engine will go back into the car.
The best for me would be to keep A/C compressor at its original place (probably better to say - side) but don't have idea how to do that ...
P.S. I hope I'm not messing up this thread
Thanks Tony. The head you did for me was a work of art and i appreciate the effort you went to with the oversized valve seats to go with the new valves.
I'm happy with the way the car drives. It has such a useful power band that doesn't need high rpm to find.
Now if I could sort the leaking gearbox out the car would be mechanically 100%Comment
I behave myself on motorways and A roads but my step son laughs like a drain from his car seat in the back when I accelerate quickly. My other half trusts my driving after I took her for a rapid, road legal and very precise excursion through the twisty roads in the mountains of the South Island in NZ. So she's OK with it too.Comment
2013 Touareg TDI /// #farmenwagen
1990 Cq /// Project: Because RacecarComment
If the stock pistons in an RS2 are similar to the AAN pistons, you should be good for ~550awhp before the ring lands are likely to give way.
So... you may be near the limit, depending on fuel and if you're running w/m injection.2013 Touareg TDI /// #farmenwagen
I mean of course it would fit but question is about Main radiator and AC condenser inside engine bay at original place .....
i think im going that route on my stroker build to..
