Kind of late to the party and did not get a chance to read the rest of the thread but just thought Id shed some light on Wossner pistons from my own discovery and ask a few questions:
1. Do you mind sharing what you got for piston dish volume?
2. What head gasket did you use? AAN is 82.2mm max bore @ 1.60mm thickness fully compressed so did you take an AAN head gasket and bore it out?
3. Were you ok with your pistons sitting above deck?
From dealing with Mahle Motorsport , I have discovered (the hard way) that Wossner publishes incorrect data on there website.Lets assume they did publish correct data though:
http://www.wossnerpistons.com/produc...e?cookietest=1
Dome Volume = -19.7 cm³
Compression Height = 30.2mm
TDI Block = 236.5mm deck height (not 236mm as often published)
TDI Crank stroke = 95.5mm
Connecting rod Length = 159mm
So you would need a piston that a Compression Height of : 236.5 - (95.5/2 + 159) = 29.75mm
So by using the Wossner pistons , your pistons are now sitting 30.2mm - 29.75mm = 0.45mm above deck.
Not a huge issue if you are running a 1.6mm thick head gasket when compressed (which from the images they are) however lets work out your CR.
Cylinder head CC = 44cc (for a 4V/cyl stock size valve pockets)
Cylinder head gasket CC (AAN head gasket bored out to 82.5mm and a max thickness of 1.6mm) = 8.49cc . with pistons sitting 0.45mm above deck means that cylinder head gasket volume is reduced from 8.49cc to 6.09cc
Vc = 6.09cc + 44cc + 19.07 = 69.69cc
82.5mm bore x 95.5mm stroke = 2552.5cc : Vh = 510.50 cc / cylinder
Based on my math a 82.5mm bore piston (for me) will yield the following:
E (compression ratio) = (Vh + Vc) / Vc
= 510.50 + 69.69 / 69.69 = 8.3:1 CR
Kind of low CR no?
Originally posted by diesel des
View Post
Kind of low CR no?
