Audi Coupe OEM+ Interior Lighting Guide
This is a sticky topic.
  • Flat on my back
    • Jan 2007
    • 2449
    Wow...
    Is there any way of powering the DL switch on the bench to check the bulb operation before it goes back into the console?
    Works on the bench, not in the car...loom fault...type of thingy.
    Carlos.
    • Jas11n
      • 5067
      On the actual push button switch, yes mate. Apply 12v to the pins on the bottom, using the earth post as pointed out above.
      On the drivetrain image I purposely didn't say anything about that. Reason, apply 12v in the wrong area and you'll do what I did and blow that black three legged transistor thingy when I hooked up the multiplug the wrong way round.
      Check the new bulb before you solder, if it's ok but won't light when back in the car, suspect wiring or faulty circuit board.
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
        Jase have you got any more info on how you did the door handle strips?
        • YELL MAN
          • Dec 2005
          • 535
          • Country: Shetland Islands
          #154
          Good write up I will be tackling the aux gauges and diff lock this weekend
          1994 Indigo Blue S2 coupe
          1994 80 Avant 1.9 TDI
          2005 Yamaha Fazer 1000
          1953 AJS Model 18S
          • Jas11n
            • 5067
            Missed your question there Alex.
            I didn't take any pictures when doing them, I had my "on a mission" head on and wasn't wholly certain they would turn out the way I saw them in my mind.
            Tell you what, I've got a couple of spare door pulls now, I knock up one tomorrow with pictures. It's not as hard as it looks.
            Get out your Blue Peter badge in readiness
            • A80Avant
              • 10873
              • Country: Greece
              #156
              hey jase,did you get the pm with the photos i sent you?
                Nice one Jase
                • Jas11n
                  • 5067
                  What photo's are those mate?? Last PM from you was 23-11-08 and no photos attached or anything
                  • A80Avant
                    • 10873
                    • Country: Greece
                    #159
                    sending you a pm again now.links to my photobucket
                    • Jas11n
                      • 5067
                      As far as I can tell, there are three versions of the seat heater switches.
                      The shorter versions were used earlier in the models life. They are very similar to the headlamp level switches. Two relays were on the aux relay carrier, one for each seat. They were replaced later on with the larger versions and the relays on the aux carrier disappeared. On removal you'll know which you have due to there size.
                      I haven't presently got an earlier shorter one, though I should have two of them in a week or so. You can see the difference between the size of them below. One shorter and two versions of the later longer ones.
                      Shorter = 5 pin
                      Longer = 6 pin
                      They do not swap with each other.
                      I have two of the later big versions (which are probably the very last of them due to them having LED's from the factory).
                      The difference with the two versions of the larger switches is the source of the illumination, differences with the circuit board and a slight difference of the clear plastic light refractor inside.
                      If you have this version below, easy job to replace the bulb, with either a new red bulb (Maplins code >>> PG78K), or a red LED (CJ70M), Refer to the control drawing further down the thread for the two solder points and the polarity (Led shorter leg = negative) Use a matchstick or similar superglued to the top of the bulb and withdraw through the hole in the top of the light tube while de-soldering.
                      If you have this below, then it's get complicated. There is no hole in the top of the clear light refractor, this version uses a clear 3mm LED that shines red.
                      This means you have to do some major de-soldering. You will need a de-solder pump for this and very fine tipped soldering iron.
                      Ok, how to open them up.
                      Remove the front cover as usual, get your blade and slot it carefully down the side of the rear of the switch. The inner unit is again clipped behind a couple of tangs on the inside of the outer case. The switch withdraws from the front
                      You are going to have to remove that massive copper heatsink. Not only is is soldered to the board in three places round it's edge, but also on three places on the centre of the board itself. Use the drawing below. You need to de-solder all the red arrowed points
                      And removed
                      You have to remove it to be able to remove the clear light refractor. Part of the light refractor is a switch of sorts, that has to be de-soldered to be able to finally get to the OEM LED. The points needed to be de-soldered here are the blue arrowed ones
                      • Jas11n
                        • 5067
                        Again with this switch, there is a tiny part you need to watch out for. A rounded tipped pin sits inside the clear plastic with a spring behind it. If you aren't careful here, that pin will either fire off and you'll never see it again, or it'll have your eye out. It's job is to sit in the position notches on the upper inner rim of the rotary knob
                        Now you can finally get to the LED. Refer back to the drawing above to the de-solder points. If replacing with a red bulb, it doesn't matter which way round you solder it, but if you replace with another LED, the shorter leg needs to go to the earth side shown above
                        I used a CJ70M 3mm LED for this
                        Once done, start to reassemble it. Due to the small components on the board, best be quick with the de-soldering and re-soldering. Heat kills small components
                        Testing it is illuminating ok,
                        Slotted back in the outer casing
                        Done, with the usual out of focus dark shot at the end ops:
                        • Acidburn
                          • 13459
                          Nice write up jas, did you manage to get the shorter switches off ebay or something? i'm after 1 more of these as i've got 1 of them and two of the longer ones, the longer one's came with a cut up loom which I can't use now so I might just ebay them and keep searching for the smaller switch.
                          • Jas11n
                            • 5067
                            Switches coming from germany
                              I need to redo one of mine as its marginally brighter than the other dash switches and its irritating my OCD subconsciousness
                              • Skull
                                • 3506
                                • Country: Slovenia
                                #165
                                Well i have put 2 bulbs in my switch, because the numbers were very bad lit. around 0.5w each, factory coloured in red... the result is very nice.
                                Audi Quattro WR
