Cheers Steve. I’m aiming for a good quality end result.
Made a start on the back end. Everything cleaned and soaked in penetrating oil.
Most of the bolts have been sprayed in under seal which is messy but has reduced the rust.
It’s going to be fun dropping the struts as the car is up on the lift and I can’t drop it as the gearbox is being held up by a ladder. I did intend to do the front first, then rear. I will have to climb into the boot somehow and see if I can get the strut top bolts undone.
The dif oil drain isn’t looking good.
