Originally posted by Tractor Dave
View Post
My Coupe project
Originally posted by jp_paul View PostYou're just slightly ahead of me! Can't wait to start using the Xmas present to myself - a blast cabinet .
Can't fit the subframe in it though Nothelle S2 Avant
- 1 like
Originally posted by Tractor Dave View Post
Thanks for the link. Santa gave me some money for Christmas so I just ordered one with it
I bought a bag of 0.5-1.25mm glass grit for media; apparently lasts longer and doesn't clog like alu-oxide, and is much cheaper. Not had chance to fire it up yet though - had inner cv's to do on the Passat which was an unwelcome distraction!
Indeed. Mine came out with some gentle persuasion. As mentioned on the other thread, the arm is plastic so heat can't be used - once I'd for the circlip off, I grabbed the pin with some mini mole grips to rotate it and break the corrosion induced seal, then pressed it up and out with pipe grip pliers.
- 1 like
Originally posted by B5NUT View PostWhat are you doing about the coating power or epoxy?Nothelle S2 Avant
Don't write off the powder coat as being rubbish... Yes its probably not as long lasting as hot dip galvanising but, check with the powder coat what exactly is going on... My go to powder coater uses epoxy powders (both zinc and colour coat) and has done for years since acrylic powder fell out of favour as the poor flaky and brittle solution it was.
Maybe you could ask for it if its not their usual stuff?
I live near Leicester and the Caterpillar construction machine place at Desford sends work to my powder coaters. The 'cat black' powder does seem to be tough and is used in pretty full on applications.
Originally posted by steve briance View PostDon't write off the powder coat as being rubbish... Yes its probably not as long lasting as hot dip galvanising but, check with the powder coat what exactly is going on... My go to powder coater uses epoxy powders (both zinc and colour coat) and has done for years since acrylic powder fell out of favour as the poor flaky and brittle solution it was.
I live near Leicester and the Caterpillar construction machine place at Desford sends work to my powder coaters. The 'cat black' powder does seem to be tough and is used in pretty full on applications.Nothelle S2 Avant
