My Coupe project
  • John.
    • 2615
    Originally posted by Tractor Dave
    Now that's very interesting. I'm M10 rear M12 front mind.
    The shorter of the bushes I could only get in M12 (standard rubber I'm talking about, not poly) so I'm using a sleeve with the M10 bolt.
      • Dec 2017
      • 5992
      Originally posted by jp_paul
      You're just slightly ahead of me! Can't wait to start using the Xmas present to myself - a blast cabinet .
      Can't fit the subframe in it though ​
      Thanks for the link. Santa gave me some money for Christmas so I just ordered one with it
      • SteveH
        • 4460
        I hope you don't plan to sand blast the speakers
        91 Modded 3B
        14 A6 Avant Black Edition
        • jp_paul
          • Aug 2010
          • 92
          That was an easy sell
          I bought a bag of 0.5-1.25mm glass grit for media; apparently lasts longer and doesn't clog like alu-oxide, and is much cheaper. Not had chance to fire it up yet though - had inner cv's to do on the Passat which was an unwelcome distraction!
            • Dec 2017
            • 5992
            I was waiting for that
              • Dec 2017
              • 5992
              It seems a few of us are at this stage and all having the same issues.
              I got the little circlip off but the pin is solid.
              • jp_paul
                • Aug 2010
                • 92
                Indeed. Mine came out with some gentle persuasion. As mentioned on the other thread, the arm is plastic so heat can't be used - once I'd for the circlip off, I grabbed the pin with some mini mole grips to rotate it and break the corrosion induced seal, then pressed it up and out with pipe grip pliers.
                • Bowie69
                  • Nov 2013
                  • 2675
                  I can't see any major rust underneath which is always a bonus.
                  Take the rear heatshield down from above the back box, there will likely be some to repair, or at the very least treat.
                    • Dec 2017
                    • 5992
                    Everything gone to the sandblasting place.
                    • Bowie69
                      • Nov 2013
                      • 2675
                      Very familiar sight!
                      (apart from the brake shields, of which I have none)
                      • B5NUT
                        • Sep 2021
                        • 1071
                        What are you doing about the coating power or epoxy?
                          • Dec 2017
                          • 5992
                          Everything you see in the boot is getting two stage powder coat. 1st is a zinc based primer and second satin black. Not as strong or durable as epoxy or hot dip galvanised but this is going to be a summer car garage queen like the Nothelle
                          • steve briance
                            • Aug 2014
                            • 1455
                            Don't write off the powder coat as being rubbish... Yes its probably not as long lasting as hot dip galvanising but, check with the powder coat what exactly is going on... My go to powder coater uses epoxy powders (both zinc and colour coat) and has done for years since acrylic powder fell out of favour as the poor flaky and brittle solution it was.
                            Maybe you could ask for it if its not their usual stuff?
                            I live near Leicester and the Caterpillar construction machine place at Desford sends work to my powder coaters. The 'cat black' powder does seem to be tough and is used in pretty full on applications.
                              • Dec 2017
                              • 5992
                              I love the stuff. Well done, it's very durable. My Avant was done nearly 4 years ago and it's all like new
                              • steve briance
                                • Aug 2014
                                • 1455
                                Zinc rich powder will do the trick, its like baked on bilt hamber eletrox
