My Coupe project
  • SteveH
    • 4460
    Originally posted by Bowie69
    I found no need for this tool, with a wiggle the input flange just came off.
    91 Modded 3B
    14 A6 Avant Black Edition
      • Dec 2017
      • 5991
      Quick update whilst I warm up having a tea break.
      There was a nice clear mark where the larger old seal sat. I put the new seal in to match. I used the old seal back to front to gently drift in the new seal.
      On the other side I used a 46mm socket and marked the position of the old seal.
      Then used it to drift in the new seal.
      This is how I removed the old seals.
      The flanges got a clean up and coat of zinc.
      Now torque settings. Set my wrench to 10nm. Once I reached that I re set to 25nm and went for the 90’. The 25nm was reached at about 80’. So, figure stated above appears correct. This was using new bolts lightly oiled.
      • Bowie69
        • Nov 2013
        • 2675
        Very good
        You are restrained in removing the seals, think I managed to just pry them out with a pry bar
        You painting the diff?
          • Dec 2017
          • 5991
          Very good
          Probably will
            • Dec 2017
            • 5991
            Got my blasting cabinet set up.
            Works quite well but makes a lot of dust as the door seal isn’t brilliant.
            • B5NUT
              • Sep 2021
              • 1071
              I had a lot of dust issues with my cabinet, and it's all down to the massive amount of air your pumping into the cabinet. I upgrade (drilled another 50mm hole) my cabinet to have twin 50mm outlets and the dust has reduced by a massive amount. Also fitted some traps in the pipe work to catch some of the escaping shot.
                • Dec 2017
                • 5991
                Brilliant
                • steve briance
                  • Aug 2014
                  • 1455
                  What sort of air supply are you using? As the owner of a proper lift, i imagine you have proper air as well...
                    • Dec 2017
                    • 5991
                    It's a hefty belt driven monster with a big tank but it recently sprung a pin hole
                    My fault for not draining the water daily for some 20 years of ownership.
                    Now, I thought I would treat myself to a new one but got a shock when I saw current prices
                    So, despite knowing it's risky, I intend to fill the hole with weld
                    • steve briance
                      • Aug 2014
                      • 1455
                      Proper air ​​​​​​
                      I have 13cfm 200L tank set up. Not enough for blasting but fine for spraying which is nice but i think if I could, i would be doing a lot more blasting than spraying!
                      • LSG
                        • May 2010
                        • 897
                        The silver lining Dave is it now can drain it's self
                          • Dec 2017
                          • 5991
                          Prop shaft is looking rusty.
                          So set about it with my favourite wire wheel
                          Some 30
                          Minutes later we have a rust free prop.
                          I have a new centre support to fit as the original has seen better days. I also have a new cv for the rear joint as it has lots of play. The front joint is fine and will just get cleaned out and new grease. It will get painted as well. I’ve just coated it with Bilt converter for now.
                            That wire wheel is very impressive!
                              • Dec 2017
                              • 5991
                              It does a good job. I now only use lessmann (German made) wheels as they last really well.
                                • Dec 2017
                                • 5991
                                I’ve been putting this job off as it’s my least favourite.
                                The Audi underseal is very good at hiding rust.
                                You think all is good until you remove some and follow the rust up the seam.
                                It’s going to take me a couple of days at least to do just the cleaning.
