Black Ur Project
    • Dec 2017
    • 5999
    Yes, I got it back after a week. You take the v5 to the post office with another form declaring its mot exempt and they send off for you.
    • B5NUT
      • Sep 2021
      • 1071
      I'd never heard of a tumbler before, look like an interesting device. I wonder how well it does on the thicker stuff. I take it you have given up on the blasting cabinet. They do make a bit of a mess and with electricity prices at the moment they are not cheap to run, as it really does take it out on the compressor.
        • Dec 2017
        • 5999
        I'm still using the cabinet for medium sized objects but those tiny speed nuts are impossible to blast or wire wheel.
          • Dec 2017
          • 5999
          Base temporarily sorted.
          I made a start cleaning inside the boot.
          The nearside is going to need a patch welding in.
          The offside isn't bad at all.
            • Dec 2017
            • 5999
            So after cutting out the rot in the boot, I found a bit in the gusset plate as well. I will need to cut that out too. Could have been a lot worse mind.
            And before welding I thought I had better disconnect the ecu. Oh dear, looks like I'm going to be busy here as well. Several wires have been cut. I wonder why and what's not working?
              • Dec 2017
              • 5999
              Onto welding.
              A template was made from card.
              And a patch cut.
              Got the welder ready but just discovered I'm out of weld through primer. Doh
              • K Simmonds
                • Dec 2007
                • 7627
                I will now only use my sand blasting cabinet outside, and I only use it for five min's at a time to give the compressor a break, I like the tumbler idea for small parts like fixings...
                Do those cut wires look concerning, I wonder why so many have been cut, I'm surprised it runs at all with that many snipped off.
                1990 B3 2.0 80 quattro.
                1992 C4 2.8 Avant quattro
                1994 MTM RS2.
                1998 B5 TDI quattro Sport.
                2000 B5 TQS.
                  Check the wire colours against Phill Payne's website, something weird going on.
                  • Ian Simmonds
                    • Jun 2005
                    • 2858
                    I think there’s only several wires that you need to make it run, but agree with Kit, that’s at best, slightly alarming. Also, remember our conversation about this era being very much a transitional period for the quattro from homologation to road car, so the wiring will be very specific to the build year and chassis number. It’s likely to have anomalies between BU82&83.
                    93 MTMS2 Avant
                      My 84 ECU loom has some spare wires in it, there's actually a duplicate sensor plug near the WOT enrichment valve on the firewall that does nothing at all.
                        • Dec 2017
                        • 5999
                        Cheers John. Concentrating underneath the car for now. Will move to that later. It's easier to do stuff in the car when it's off the ramp and I can fully open the doors. Having fun welding the patch in the boot today. A small patch got a bit bigger when I discovered a bit more rust and I rediscovered how much fun welding thin metal is
                        • ottawa coupe
                          • 860
                          Gotta love it when ypu're just about to close up a hole and the metal says nope and it all just melts away.....
                          1993 UrS4...aka the rocket powered living room
                          • 4WDrifter
                            • Nov 2012
                            • 1251
                            #163
                            Hi Dave, been there done that!
                            1996 S2 ABY Coupe silver
                            2003 S3 8L dolphin grey
                            2014 RS4 B8 prism silver
                            • 4WDrifter
                              • Nov 2012
                              • 1251
                              #164
                              After
                                • Dec 2017
                                • 5999
                                The very same spot
