Originally posted by martinjs
View Post
My 3B Coupe project - Total rebuild
This is a sticky topic.
i agree it is not ideal to tune like that but at the time when all these cars were tuned there were no bigger MAF's as robust as they are now, and not so many people interested for a tuner to invest to a bigger maf idea.
since now it can be done, i presume that if i was still using motronic, id like to be as analytical as possible.
Today, in an effort to fix this:-
http://www.s2forum.com/forum/showthread.php?t=51079
I have fitted a different gearbox and a fully re-furb'ed propshaft. The good news is that the gearbox noise has gone, the bad news is that in trying to tweak the exhaust fitting to get more ground clearance ( f**king speedbumps ) I appear to have made it 100% worse as it's now touching the front subframe and the rear diff, causing some horrible vibrations. Should be a quick fix tomorrow though.
Also slightly worrying was the state of the clutch release bearing after only 2K miles
This was the Sachs bearing that came with the Sachs race clutch kit. I've fitted a new Audi bearing which is also Sachs branded so we'll have to see how that lasts. Not 100% certain whatr was causing the noise but I think it was something in the box rather that thee bearing. I'm going to use my new JH Motorsports DVD to strip the gearbox and see if I can find out what was wrong with it.
Big thanks to ChrisP and Brian Tonks for helpingsigpic
Originally posted by Tonks4x4 View PostNo worries I am still chuckling to myself about the tea incident
Got the exhaust refitted today and all is well, also tweaked the gearbox linkage to improve the shift, which is now much better. Made a skid plate to protect the rear flexi from speed bumps
Shame I didn't have an titanium, could have made going over speedbumps funsigpic
Top tip on the skid plate, I could do with making one of those.
One of these days I’m going to catch a break with this project!!
Went for mapping yesterday and it didn’t go well, we found 3 problems:-
1.Lambda sensor is not functioning as it should. Not too much of a problem but annoying considering it’s fairly new.
2.Compression test revealed that the compression ratio is higher than I thought, and planned. I did a test myself a few weeks ago and got 14bar across all cylinders. I thought this was the top limit on a new engine from figures I seen in the factory manual. On re-checking this I found that it’s actually 13bar top limit. This means that I’m running a higher CR than stock, not something I wanted. Stock CR is 9.3:1 I’m estimating that I’m on 9.5:1 from calculations I’ve seen online. This is even more annoying as when I sent my calculations to JE for the pistons they said I had them wrong and they altered them slightly. This now means I may have to re-think what boost it will run. Any thoughts on maximum boost with a 9.5:1 CR?
3.Last but not least, the turbo is f**ked! Basically the seals are leaking quite badly when the pressure is wound up, resulting in boost leaking into the oil return line and into the sump
So the turbo is being taken off on Monday to be shipped off for a re-build. New lambda is on order and we should be good to try again.
On the plus side, even running 0.4bar boost, the car feels really good, I came back from Stokesley on the B1257, 20miles of B road heaven, and the car was flying. So even if I have to run lower boost than originally planned I still think it’s going to be quick, just might not have the headline grabbing power figures.sigpic
sorry to hear its not all gone to plan (again!) Andy, sounds like the last few hurdles now though - ****ing annoying that JE thought they knew best
Still the higher CR might make the car even more useable, albeit a tad down on the top end you might have made?
Interested to see what up with your gearbox, mine will be getting torn down when i have found another box to replace it with, might need to rent your JHM DVD!Panthero Coupé quattro 20vt
Andy the higher cr is going to effect mbt minimum best timing rather than boost at high rpm basically you will have to run less advance, you can get around this problem by using a compression dropping gasket if but that means taking it to bits again. Still say you will be able to run around 1.8 bar trailing down to red line
I'd ask Repo or Pnanassy both have stroker mapping knowledge
Video is available online
http://152.66.93.29/audi/download/JH...d_video_35.wmv
As soon as I get time I'm going to strip the gearbox and see what was up with it. nOt sure if it is just the gearbox or the fact that I put in expensive oil, but the new box is so much nicer than the old one, shifts like a knife through butter.
This is the oil I used, as recommended by Oilman
http://www.opieoils.co.uk/p-981-fuch...ion-fluid.aspxsigpic
Originally posted by Jamo View PostAndy the higher cr is going to effect mbt minimum best timing rather than boost at high rpm basically you will have to run less advancesigpic
I also have a load of redline oil but not sure if i should change to it or not?91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express
