Project: RS2 ABY
  • driftin jo
    • Sep 2007
    • 2222
    Originally posted by TimE-J
    Is that the opposite way to the standard way on the picture?
    NO, it's the standard way the factory DV is fitted.
    • Sonic
      • Jul 2006
      • 5514
      #1217
      I think mine was fitted incorrectly before the "upgrade" then
      S2Forum.com Administrator
      • TimE-J
        • Jul 2009
        • 1292
        Ok, means mine is the wrong way from standard then oopps.
        96 S2 aby Coupe. Rebuild Project
        96 mk3 golf tdi daily.
        • prj
          • Mar 2010
          • 6308
          I believe your statement to be incorrect and factory is the other way around.
            Driftin Jo is correct, this has been covered multiple times
            • Sir Buff
              • May 2004
              • 127
              • Current: Switzerland
              #1221
              http://www.audi90.ch
                Yep so Sonic has it in the right way
                • prj
                  • Mar 2010
                  • 6308
                  I wonder if it is different on AAN.
                  • Lloyd
                    • Apr 2006
                    • 1559
                    #1224
                    Originally posted by Sonic
                    Pretty certain its still in this way...
                    Are you currently using that MAC valve?
                    RS2+ (now sold...)
                    • prj
                      • Mar 2010
                      • 6308
                      I don't think he is.
                      • Rocco
                        • Aug 2007
                        • 6393
                        • Country: Spain
                        #1226
                        1.8 coilpack conversion done after one of the coilpacks gave up the other week
                        There is a slight problem when shifting gears at high RPM, the car only boosts to 1 bar for a couple of seconds before it shoots back up to 2.2-2.3 bar like it should be doing.
                        Suspected DV sticking issue and i'll be getting it looked at with Will in a couple of weeks... that and i NEED to get some logs from the car now i have Zeitronix setup properly
                        Any news about this Andy??
                        Me and my friend Simon we are having the same issue when shifting gears hard in the top rpms.
                        I noticed that if you just leave the throttle for a second and WOT again your car pulls strong again boosting like it should.
                        My friend's DV is forge 007p too and mine is the biggest dhalback DV available to buy...
                        I'm going to try mechanical boost with a valve to check the wastegate and also uninstalling the DV.
                        • Sonic
                          • Jul 2006
                          • 5514
                          #1227
                          No removed by request of Dmitri
                          Yeah the car is up with Will at the moment having this looked at. I'll make a post when i know more but your symptoms sound the same as mine.
                          • A80Avant
                            • 10873
                            • Country: Greece
                            #1228
                            Oh no. What's the problem now?
                            sent with Nokia 5110
                            • Sonic
                              • Jul 2006
                              • 5514
                              #1229
                              As above with Rocco really - when shifting at high rpm and going straight back onto WOT there is a distinct lack of boost for a second, before "normality" resumes and boost kicks in e.g. i'm only seeing 1-bar for a second at WOT rather than 2.2bar.
                              It has the effect of making the car feel like its got lots of turbo-lag after a gear change.
                              • Biturbo
                                • Aug 2011
                                • 591
                                • Home: Lithuania Current: United Kingdom
                                #1230
                                Hope you sort this problem soon.
