Jogi's New Project
  • jogi730
    • 2335
    OK, engine out
    Off to tuner next week for reassembly
    Chris
    Audi 90 quattro (Typ 85)
    20v turbo conversion
    • gavs20v
      • Sep 2004
      • 3057
      woohoo! progress, good to see buddy
      S2 Cabriolet.........
        Nice to see some progress here what's up with that catch tank setup? doesn't look right
        • jogi730
          • 2335
          Suggestions?
          Chris
            I think Jamo is referring to the fact that usually the catch tank return is below the oil level.
              If you look at the catch tank the bottom of the tank which is normally the return to sump is connected to the block outlet for oil vapour this is supposed to be connected to the top of the catch tank.
              • jogi730
                • 2335
                Suggestion for improvement?
                Is there a 'how to' write up anywhere of installing catch tank with return. Is there a huge benefit to this?
                Chris
                  Chris
                  • LHD_Kid
                    • May 2006
                    • 3696
                    #69
                    • Baldy
                      • 469
                      • Home: Sikkim Current: British Antarctic Territory
                      #70
                      Just read this thread chris will be nice to see the old girl back on the road.
                      good luck with the build
                      Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
                      0-60 4.9
                      1/4mile 13.5
                      • jogi730
                        • 2335
                        Not seen much from you recently. How's your girl running? Did you ever sort your IC?
                        Many thanks
                        • Baldy
                          • 469
                          #72
                          just spent the past couple of weeks sorting my body work out and getting the paint done (see thread on classic audi) not played under the bonnet 4 a while but i dare say the urge will take hold again funds permitting
                          0-60 4.9
                          1/4mile 13.5
                          • jogi730
                            • 2335
                            6 Speed Gearbox
                            Happy New Year to everybody!
                            Well I can report a small amount of progress on this one.
                            My engine has been reassembled and is now waiting for my tuner to finish his dyno cell. He is waiting on just a few items to complete this now, so once there, full steam ahead with mapping some engines.
                            TOday however, I did finally get around to fitting the 6 speed gearbox using the custom fitting kit from Patrick in Belgium.
                            So it was out with the old
                            And in with the new:
                            Showing spacer to make the new 6 speed fit
                            All in all, not much progress, but a small amount forward is better than none.
                            Chris
                            • Acidburn
                              • 13459
                              Glad to see you've kept the faith mate, it will be worth it in the end
                              • gavs20v
                                • Sep 2004
                                • 3057
                                ooooooh pretty. Really great start to the new year seeing you have some progress on this mate. Maybe someone switched the little light back on in that tunnel? Is it back with H now?
                                Which driveshafts are you planning to use?
                                Gav
