UrS4 2.2T Avant project
Tomas,dont you have a Log file where we can see the boost pressures,Rpms,AFR,etc??
with 1,7bar, did you mean 1,7bar since full boost until rev limit?
7200rpm limiter?RED Mitsubishi Lancer Evolution VI TME nº 16 of 250
LWB Audi Sport Quattro projectComment
so now, will you have three 20VT engines for only your avant?
highly modified 2.2
getto build
stroker
???RED Mitsubishi Lancer Evolution VI TME nº 16 of 250
No I don't have a log, have to take one next time. I would like to get the measured wideband AFR to the log, but I don't know how to do it..? 1,7 at the red line, but the boost isn't controlled at all, so there isn't 1,7 bar lower down. As you can see in the graphs the power just rises up to the red line, hand in hand with the boost. There would be a lot more power awailable between 4000-6000 rpm area. The limiter seems to be in that area.
BMW 740iA e38 - ProjectComment
i only have now a stock AAN engine with 170K kms,the one in the +500 hp black coupe and the PK-Motorsport engine
and only one car running.
i still have a Dutch 80 Competition without plates,ready to be plated but probably i will sell it.
and i also have the coupe quattro B2.... if you want it
Would love to buy your coupe and the bodykit, but I'm little short of money atm to trow in the hobby of ours.
hi thuppu
congratulations to your income. have you tried with a DriftBox 100-200kmh times? I have a c4 s6 avant and similar hardware. 2.6bar-2bar (aral ultimate 102 octane) out of the top because the egt is too hot. also with super hx 40 16cm ², vems, mech. cylinder head. 100-200kmh best time 7.4sek.
DriftBox power 408kw at wheels.
this winter I will rebuild on E85, then cruise over 2bar from 7000 u/min
408kw @ wheelComment
