Engine is now back in one piece, but cant get it to turn over.
Been trying to track down the issue, battery ok. starter is getting voltage but solenoid only getting a couple of volts and cant hear fuel pump when igntion switched over.
Got an 044 pump fitted so can normally hear it when it starts. I assume I should hear this once ignition is switched over to position 2. Using immob the dash lights etc all work, and when you dont you get no dash lights at all.
Any advice appreciated.
