1981 UrQuattro story
  • turbofan
    • May 2008
    • 30
    • Country: Latvia
    #76
    I hope You find the pipe.
    If not, use this.
    Black S2 Avant
    • Skull
      • 3506
      • Country: Slovenia
      #77
      thanx!
      So it is an MB only pipe, i will block it...
      found a dodgy wire on the idle switch:
      after searching on the internet for engine pics, i found the idle setting screw
      it has been blocked with silicone... , probably the ring seal is leaking...
      this is the sensor i need.
      Audi Quattro WR
      • chezz
        • Apr 2007
        • 440
        Originally posted by pasbogdan
        No vacuum at that side.Only at cone/plate.Only dirt not getting there can be stoped by a cap.
        Pretty sure that this is under vacuum and for that reason it should have the 'bung' replaced.Air is being drawn under the flap/paddle side via this hole.
          Ur quattro, K-Jetronic idle mixture adjuster..
          The amount of air drawn in on this setup is very small, the hole is in fact not a hole at all but a tube containing a spring loaded 3mm allen key extension. You fit your adjusting key into it and push down against the spring until it engages with the flap adjuster, tweek it and then let it spring back up to check the result. Covering the hole with your finger should make no difference to the idle speed. It has to be said though that sometimes people remove the mechanism so that you adjust with a long allen key straight onto the flap, in this case the hols does have to be blocked for the car to idle correctly. My car has a Treser metering head which is a larger, downdraft unit with the air filter above and has a threaded bung covering the adjuster hole.
          The standard unit just needs the bung to keep the dirt out.
          • Skull
            • 3506
            • Country: Slovenia
            #80
            this is the past weekend video:
            now we just need to sort the idle, fix the oil leaks, and the quattro is in da business again
            Audi Quattro WR
              #81
              My recollection is that the 'screw' underneath the silicone on the throttle body is a brass screw with a small black rubber ring seal, and a pointy tip, that needs to be cleaned of black gunk periodically.
              I think it is common to Mk 1 and early Mk 2 K-Jet Golfs, and other VAG cars of that vintage.
              Someone on here should be able to dig up a photo.
              You're making good progress, as usual.
              Kind regards.
              • Skull
                • 3506
                • Country: Slovenia
                #82
                macspring: the screw is inside, it was covered with silicone. i will just need a new ting seal...
                Audi Quattro WR
                • Skull
                  • 3506
                  • Country: Slovenia
                  #83
                  i need some brake info fast!
                  i have a chance to buy a set of 2 piston Girling 60 calipers.
                  do they fit on a urquattro which had stock single piston calipers? Just need longer brake lines?
                  Audi Quattro WR
                  • jsws3
                    • Apr 2012
                    • 1174
                    I have some ur 20v front brakes with good disks and pads if your interested .
                    • URquattroGus
                      • Aug 2007
                      • 547
                      Yes they will fit (did this a few years ago)
                      Don't forget you will need the matching floating caliper carriers and of course the bigger discs.
                      I also had to trim down the tin brake backing plate by just a tiny bit. Probably best to go for some braided lines whilst you're at it too.....
                      Angus
                      (1984 ur quattro)
                      • Skull
                        • 3506
                        • Country: Slovenia
                        #86
                        i should get lets say urquattro 20v brake lines?
                        something like this:
                        http://www.ebay.co.uk/itm/Goodridge-...item5d37f0d6bb
                        Audi Quattro WR
                        • Skull
                          • 3506
                          • Country: Slovenia
                          #87
                          yep, they fit, just need longer brake lines.
                          do the rear S2 coupe brakes fit the urquattro?
                          Audi Quattro WR
                          • Jckssn
                            • Dec 2006
                            • 15
                            Rear Ur-s6 i think are bolt on, vented 269mm discs!
                            Audi 80 Competition (This winters project. AAN, 01e, VEMS, gt3076r, E85 porschebrakes 5lug conversion etc.)
                            Audi A6 2.4 quattro -1999 dailydriver
                            • Skull
                              • 3506
                              • Country: Slovenia
                              #89
                              thanx for the tip!
                              Audi Quattro WR
                              • URquattroGus
                                • Aug 2007
                                • 547
                                I think the 20v ur has the same rear calipers and discs as urs6??
                                Angus
                                (1984 ur quattro)
