UrS4 2.2T Sedan project
  • sofronieva91
    Banned
    • Mar 2015
    • 184
    • Country: Russian Federation
    #91
    good luck
    • s0_big
      • Dec 2009
      • 685
      Today was the day
      After a 800km trip which started today at 3am i'am finally home. Everything went wery good. I thought i would get some more power out of it but i'am happy with how the car preformed anyway (my first build). No problems at all. I was told that if i pushed over 2bar it will may be a risk because i ran it on 98oct so i decided to stop at 2 bar. We tried to push it up to 2.3bar and i went good but i decided to play safe and vent down to 2 bar and 378whp (461hp at crank) was highest hp it ran. Unfortunately i forgot to record a video but the tuner recorded the dyno runs so he will upload it later on. Some pics of my day
      Power is measured on the wheels!
      • Wrath
        • Jan 2011
        • 779
        Nice ! That´s something I would like to have in my car when the Engine is ready...
        1995 Audi S6 - AAN (~350hp)
        2008 BMW 530xd (235hp)
        2011 KTM 990 SMR - custom tuned (120whp)
        • V6quattro
          • Sep 2008
          • 949
          Nice. Just enjoy your car now. I'm running a Precision 6262 and at my first dyno session i was making 500hp at the crank with 98oct. Now after some time tweaks and E85 im at 700hp
          So just enjoy and improve it now.
          • s0_big
            • Dec 2009
            • 685
            Thanks for the kind words. I'm really enjoying the car. It pulls lika a train as far as you keep the revvs up. I will polish the car tomorrow because it's worth it now.. In the weekend i will put many miles on it and hopefully i can find some old gentlemen in their porsches and smoke their asses
            • s0_big
              • Dec 2009
              • 685
              Video
              A little video from the dyno
                #97
                Great progress / result. Looking forward to a drive by video.
                Can the flywheel be used with an oem clutch ?
                I presume the flywheel is lighter than the AAN flywheel ?
                Thanks.
                • popdemonic
                  • Dec 2007
                  • 1304
                  • Country: Thailand
                  #98
                  wow impressive on the torque jumping from 3.5 to 4.5k rpm.is this BB or journal bearing CHRA?
                  one of a few I5 from Asia.
                  • s0_big
                    • Dec 2009
                    • 685
                    Flywheel
                    Can the flywheel be used with an em clutch ?
                    Thanks.
                    The flywheel is used with 707 Sachs pressure plate.
                    Yes it's Lighther than AAN flywheel. But How much i don't know.
                    • s0_big
                      • Dec 2009
                      • 685
                      Hello. It's just a journal bearing. Precision 58/58 turbo.
                      • mushasho!
                        • Apr 2007
                        • 163
                        So what was the limiting factor stopping you from making more power?...
                        _Rubí_
                        • s0_big
                          • Dec 2009
                          • 685
                          The tuner said that it was a gamble to push over 2 bar with gasoline. And the exhaust temp was going up to much. We went up to 2.3 bar but with no big difference in hp. The tuner blamed the fuel.
                          • prj
                            • Mar 2010
                            • 6308
                            I am not sure how you arrive at the 28% drivetrain loss (483 stated hp).
                            I usually tend to see 20% on these cars. And 378whp would be ~454hp in that case.
                            That said, on 98 RON this is a perfectly normal result. There is not much use going more than 1.9-2 bar on pump fuel. Result is only heat and detonation.
                            I don't know what the dyno's ramp rate was set at, but the spoolup seems a little late.
                            A HX35 Super makes the same power and has 2 bar at 3.9-4k.
                            WMI or E85 would help a lot. In fact I don't see why you don't use E85 with dual map switch if you are in Sweden, as E85 is almost more common than 98 RON over there.
                            • s0_big
                              • Dec 2009
                              • 685
                              That was me writing wrong... The dyno sheet is "correct" . I don't know anything about their dyno ramp rate. what is that?
                              The reason i decided to go with gasoline was that i didn't have to build a new fuel system. Just dropped in a 044 and new filter, injectors. Maybe in the future i will change to E85 but for now it's going to run on 98 gasoline.
                              • s0_big
                                • Dec 2009
                                • 685
                                Some carbon
                                Couldn't resist to buy some carbon from Aron. Also fitted my turbo heat shield.
