Urq project
I hope it fits! Will find out tomorrow. If not I have a plasma cutter....are you sure that the exhaust manifold with your turbo will fit in the ur- engine room?
with my tubular exhaust manifold(was made for s2) and gt30-35 i had to cut in the inner wing to make room for the airfilter and had just enough space between turbo and inner wing and between turbo and the bonnet
worry's for later..........
i have also a rs4 b7 gearbox waiting to go in,this will be my next job!
first with the gt35 on the dyno so i can see if my clutch will hold the power before i gonna swap the gearbox
Sent from my LG-H955 using TapatalkComment
TWINCHARGED power,zero lag
AEM W/M injectionComment
whats your plan with the ic?audi coupe quattro b2 2.2 20vt project (573hp-626nm)
You could weld a B3 or B4 Audi inner wing in the car on the right front side to give more room for the turbo and filter.Comment
Are these available new or are they a cut out from another car job?
It's in! The gearbox fits too without any tunnel bashing. Need to make up gearbox mount brackets or get some from james. Just up on a strap for now. Also need to mess with prop shafts to get something sorted that fits. The urq shaft is slightly too long. A Urs4 shaft is about 2 inch approx short but I could make up a spacer for the diff end.
Trial for of urq shaft. About 1 inch long.
Started into fitting the front brakes. They fit under the rims ok. Not a fan of the colour but the coating is good so I think I will leave it.
New starter fitted. Much lighter than the last one.
Timing belt too slack so need to make bigger tensioner. This is with a 80mm modification. Last one was ok with 82mm but due to the block skimming I need more like 85 mm.
Did that good a job with the thread lock and bearing fit I had to make up a fitting for the slide hammer to get the tensioner off.
One front drive shaft fitted with the help of Alex. Needed a6 shaft with S2 outer cv. The other shaft I had was wrong and wouldn't fit the S2 outer so another one is ordered. Front brakes fitted with pads.
I didn't measure the box but I suppose it must be longer if the urq shaft is a tad too long. About 30mm too long at a guesstimate. A spacer and a Urs4 shaft look perfect. Just waiting on a new center bearing coming then I can confirm the length of the spacer I need.
