Urq project
  • PRY4SNO
    • 767
    Car looks amazing, quality work as always Des.
    What weight of oil are you running, maybe it's too thin? I run 5w40 and when the level gets too low it gets noisy.
    2013 Touareg TDI /// #farmenwagen
    • diesel des
      • 3896
      #362
      Yea it's a 5 40 oil. Might need something more heavy then. 10 50?
      • david1980
        • May 2014
        • 1025
        10 w 50 was what I use, I found same symptoms as you till I changed and it was loads better. Silkolene pro s
          #364
          Nice - enjoy - kirkistown I presume ?
          • diesel des
            • 3896
            #365
            Yep kirkistone. Thanks guys
            • paulmac
              • Dec 2006
              • 306
              #366
              Top job des looks really well.
              • diesel des
                • 3896
                #367
                Not good news guys. It's ate something like a big end bearing in the bottom end. Bad knock. Oil pressure had been great with 2 bar idle when hot and 4 bar ish when up the revs. Then after the problem the pressure fell to 1.3 bar idle and 3 bar at higher rpm. My oil temperature gauge isn't working for some reason and the oil cooler is cool and the sump boiling. I think maybe the thermostat for the oil has let the oil boil and then do a bearing. Will soon find out I suppose...
                • V6quattro
                  • Sep 2008
                  • 949
                  Sorry to hear mate But you said your tappets ware ticking? Are you sure it does not suck air? I had the same problem. It sucked air on hard launch and the tappets started to tick. I made a good baffle and now its gone.
                  • diesel des
                    • 3896
                    #369
                    Oil pressure stayed up on and I have baffle plates so I don't think that's the issue? But don't know....
                    • V6quattro
                      • Sep 2008
                      • 949
                      I had some small changes in pressure. If the tappets tick it must be air i think? And air in to oil sounds not good to me.
                      • quattro-nick
                        • Sep 2012
                        • 1746
                        • Country: Belgium
                        #371
                        damm,bad luck des
                        i also had some oil pressure problems in the past with my rebuild engine,results,crank damage,
                        my problem was that the oilpump was sucking air on hard launches so i made the sump bigger and some baffles in it
                        I hope you do not have too much damage!
                        TWINCHARGED power,zero lag
                        AEM W/M injection
                          #372
                          That's a pisser Des - your theory about the oil 'stat sounds plausible. Hopefully a set of main bearings is the only material damage.
                            Bummer Des
                            Did you use ARP mains studs? Sounds similar symptoms to what happens when the check valve gets crushed
                            • diesel des
                              • 3896
                              #374
                              No I'm using 12.9 cap heads and they are the same length as stock. I hope to find a cause as I don't want to do this engine build a third time. I wasn't pulling massive g force so I just don't know.
                              As I was measuring good pressure at the stock pressure point are there any other galleries that could be restricted and give poor oil flow to parts of the engine like head and crank?
                              Just how hot does oil need to get to cause this problem despite having good pressure?
                              I new I should of took more notice to the noisy tappets. They were the early warning.
                              Anyhow it's out and on the stand.
                              • andy10v
                                • 5996
                                That is ********, it was looking so good on the last page!
                                Sold ABY-stock
