Some small things has happend. Radiator and IC mounts are finished. Snubmount made. Coolant hoses are fitted. 2.5" boost pipes are ready and 50mm dump valve fitted. Cutted a part off the inner wing so I could fit an short dual cone Edelbrock airfilter. Quite small filter so I don't know how it will restrict..?
Naah, don't want to make holes in the bonnet. Bumper is no problem, it's already cutted and has a fiberglass extension.
Ok, I again remember why I hate Vems!!! Yesturday tried to start the car, but no luck. At least the oil pressure rised without problems... I tried to find pictures from the net where I could see the ignition- and injector outputs(if they are right), but how can bee that all pictures of audi setups are different?! Well, downloaded the audi config and get a conflict with a ignition output and boost control output, whaaat, why? I download a ready config for audi(for easy start) and I have AAN PnP ecu, how can there be a conflict?
But anyway, if I delete the boost output then ignitions look like this. Any can confirm these are right?
I'm so close to order a second Maxxecu. It is truly PnP, just plug ecu in, save audi basemap, choose injectors and start the car. How hard can it be?
And then another thing. Downloaded firmware 1.2.2 and I have 1.8T MAT sensor, do I need a patch for this, and how to choose the patch, there are only numbers no identification of the patches, and a million different one?
