Oil recommendations and questions here - The Definitive S2 Oil thread
This is a sticky topic.
  • Lloyd
    • Apr 2006
    • 1559
    #286
    Hi Tim,
    I've been using the Silkolene Pro-S 10w-50 oil with my car for some years, track day oil temps usually around 130C, although at Spa last summer I saw 150. Oil is always changed following a track day.
    I recently changed the oil cooler for a much larger version and whilst I have not yet been back out on track, the road oil temps are already noticeably less than with the original cooler.
    My question is, should I now use a different grade of oil now that maximum track day oil temps will most likely be much lower?
    RS2+ (now sold...)
    • madpugger
      • Sep 2007
      • 1901
      Oilman,
      Audi S2
      ABY 2.2
      CT355 turbo (around 500 - 550 BHP)
      V-Power
      Usually quite spirited driving (read as flat out off every roundabout )
      Some questions...
      What oil would you recommend right after/during an engine rebuild?
      When would you change this and for what?
      Normally I'd get the engine running, do a heat cycle to then tighten the head again and change the oil at this point. Then change again after a few hundred miles. Just interested in yours and others thoughts and specs.
      Le Mans 2012
      Nurburgring 700
      1995 S2 Avant
      • oilman
        • Jan 2006
        • 996
        Originally posted by Lloyd
        Hi Tim,
        Hi
        I'd say the best thing to do is keep an eye on your oil temps for now, if it gets over 140C on track then I'd say it's best to stick with 10w-50, but if it stays under 130C, then a 5w-40 or 10w-40 could be a good option.
        Regards
        Tim
        Use the code S2F and get 10% Club Discount
        oilman's website for BMW engine oil and much more - register for news and offers
        email: sales@opieoils.co.uk
        phone: 01209 202944
        • oilman
          • Jan 2006
          • 996
          Originally posted by madpugger
          Oilman,
          Audi S2
          ABY 2.2
          V-Power
          Some questions...
          I'd use the Millers running in oil for the first 100 miles or so, changing at 50 miles, then 250, then 5-600 and put the good stuff in at 1000.
          The UK's largest independent supplier of automotive oils, fluid and parts. We've products to suit any vehicle, from full blown Race / Track weapons, to Daily Drivers looking to save money. Plus FREE expert advice & recommendations - OPIE KNOW OILS
          When it's ready, a 10w-50 is ideal
          The Nanodrive CFS is, on paper, the best oil available, but the Pro S and CFS are both really good oils, so all are good choices for your car.
          Tim
          phone: 01209 202944
          • gripper
            • Jun 2008
            • 1156
            Hi Tim,
            Can you recommend the best grade of oil to use on my coupe ?
            2.8 V6
            170k
            I rarely see oil temps higher than 100c, spirited driving(when I get the chance) on a standard n/a engine.
            My temp pressure only reads just over 1 bar when fully hot and no longer reads 5 bar +/- from cold
            It does improve with oil changes but this does not last long leading me to believe I may be using the wrong grade ?
            Any suggestions ?
            Chris
            For what this cost me so far I could have bought an S2
            • audi rs2 1995
              • 262
              • Country: Denmark
              #291
              Hallo Oilman
              Driving a Audi rs2 with 648 hp
              Daily driving car
              My Oil temperature is between 70-90 degrees
              I run Castrol 10-60W right now
              Jesper
              • oilman
                • Jan 2006
                • 996
                Originally posted by gripper
                Hi Tim,
                2.8 V6
                170k
                Any suggestions ?
                Chris
                Hi Chris
                What oil are you using at the moment?
                Tim
                phone: 01209 202944
                • oilman
                  • Jan 2006
                  • 996
                  Daily driving car
                  Jesper
                  Hi Jasper
                  90C is far too low for a 10w-60, a 5w-40 or 10w-40 is more appropriate.
                  Out of those, the best ones are the Fuchs/Silkolene Pro S, Millers CFS NT/CFS, Motul 300V, Redline and Gulf Competition.
                  Tim
                  phone: 01209 202944
                  • gripper
                    • Jun 2008
                    • 1156
                    Hi Tim, I normally put in what ever I can get my hands on that's in the 10-40 grade.
                    Last time I did an oil change I put castrol magnetic in which I don't think was really suitable !
                    • oilman
                      • Jan 2006
                      • 996
                      I think that's the issue. Magnatec is nothing special and breaks down fairly quickly, which is why the pressure starts off okay after a change, but drops off soon after.
                      I'd go for a better oil, like the Millers CFS or Gulf Competition as they are much better oils and will last longer. Alternatively, go for a 10w-50 as that should definately sort the pressure out as it's a bit thicker and all the ones we have are very good quality.
                      Tim
                      phone: 01209 202944
                      • audi rs2 1995
                        • 262
                        • Country: Denmark
                        #296
                        Originally posted by oilman
                        Hi Jasper
                        Tim
                        Thanks a lot :-) but Can i driv ón castrol power1 10w-40??
                        • oilman
                          • Jan 2006
                          • 996
                          You could use the Power 1 Racing 10w-40, the normal Power 1 isn't great
                          phone: 01209 202944
                          • Ian Simmonds
                            • Jun 2005
                            • 2858
                            With the Rallycar, I'm quite conscious of the oil when hot and whilst undertaking aggressive work. We are still wet sumped, and I wonder if, as with many rallywrecks, that the continued, shortish warm-up followed by several minutes of 'loony-tunes'... Could be better protected with a stronger oil choice.... Currently 10w40 magnatec appears okay, but would a thicker (say 10w60) protect the bearings longer in this harsh heat cycle environment.
                            VBR
                            Ian
                            93 MTMS2 Avant
                            • pasbogdan
                              • Sep 2009
                              • 1160
                              • Country: Romania
                              #299
                              VBR
                              Ian
                              Your do not hear hydraulic tappets when hot?I once tried 10w40 and at 130 oil temp tappets were screaming to come out.After 5w40 never heard of them
                              Tthings should be simple.5w40 for normal conditions,thicker for racing use taking care to let the engine get in temp before reving it(i mean more care compared to 5w40).The quality of oil is my problem..
                              • Billman
                                • 4129
                                #300
                                Tim
                                Hi Tim,
                                how does the Amsoil AMO 10-40 is compared to these oils?
                                Go Holset or Go RS4
