Oil recommendations and questions here - The Definitive S2 Oil thread
This is a sticky topic.
  • oilman
    • Jan 2006
    • 996
    Originally posted by Ian Simmonds
    With the Rallycar, I'm quite conscious of the oil when hot and whilst undertaking aggressive work. We are still wet sumped, and I wonder if, as with many rallywrecks, that the continued, shortish warm-up followed by several minutes of 'loony-tunes'... Could be better protected with a stronger oil choice.... Currently 10w40 magnatec appears okay, but would a thicker (say 10w60) protect the bearings longer in this harsh heat cycle environment.
    VBR
    Ian
    Hi Ian
    Sorry for the delay.
    Any idea how hot the oil is getting?
    Tim
    Use the code S2F and get 10% Club Discount
    oilman's website for BMW engine oil and much more - register for news and offers
    email: sales@opieoils.co.uk
    phone: 01209 202944
    • oilman
      • Jan 2006
      • 996
      Originally posted by Billman
      Hi Tim,
      how does the Amsoil AMO 10-40 is compared to these oils?
      The Amsoil is good, it's a PAO synthetic, but those ones are ester based, so a step above the Amsoil.
      Tim
      phone: 01209 202944
      • Billman
        • 4129
        #303
        Tim
        Go Holset or Go RS4
        • mouse
          • Apr 2008
          • 374
          • Country: Australia
          #304
          Hi Tim,
          What do you think of the oil test linked to here:? http://www.s2forum.com/forum/showthread.php?t=59770
          Would you consider the test methods and results to be valid?
          • oilman
            • Jan 2006
            • 996
            Ah, the good old Falex test machine This one has been doing the rounds for a couple of years now, most of those oils no longer exist in that form (all been updated or discontinued). Personally I would take it with a big pinch of salt, the oils they are comparing are apples and pears to one another and in most of these American tests the winner is always American... The Falex test machine itself is very popular at trade shows etc and gives a wow factor when people see the difference in scarring especially when oil additives are added. But, in reality it has no relation to what goes on in an engine, there is no temp control, combustion by products, shearing effect, length of time to name a few. One test that is used by reputbale oil manufacturers/blenders is the 4 ball wear test http://www.polarislabs.com/test-expl...-ball-wear.php
            Hope this helps.
            Guy
            phone: 01209 202944
            • bartolomeus
              • Jan 2009
              • 1475
              • Country: Romania
              #306
              Hi Oilman,
              I've recently rebuilt my engine, and will have a 400+ hp setup, with 1.85 BAR pressure at full boost.
              I plan of driving the car a little on the agresive side, with some flat outs and ocasionally some drag races.
              What oil will you recommend?
              After the engine rebuild we used 10w40 BMW oil for the first start of the engine and some km, then we switched to 5w40 Castrol Magnatec and then we are planning at 1000 km to switch to Castrol edge professional TWS 10w60.
              What would you suggest? I will be interested in buying some oil from you.
              Also I have another stock Audi S2 3B and planning on doing just a stage 1 remap, so I guess the turbo will run at 1.4-1.5 BAR pressure, and 270hp.
              This car will be drive seldom agresive. What would you suggest for this car?
              I'm using Castrol Edge Professional TWS 10W60 at this moment.
              • oilman
                • Jan 2006
                • 996
                I would think SAE60 is too thick, do you have any idea on oil temps when used hard?
                Guy
                phone: 01209 202944
                • bartolomeus
                  • Jan 2009
                  • 1475
                  • Country: Romania
                  #308
                  No I don't. But I will keep track of the temperatures from now on.
                  • orsum
                    • May 2010
                    • 1213
                    • Home: United Kingdom Current: South Africa
                    #309
                    type and make of oil and freq of change
                    Hi Oil Man,
                    Both cars are serviced by Audi in South Africa, both are at sea level, temps 20 to 35 deg cel, every now and then they get pushed to max top speed for about 5 min.
                    My car
                    Make - Audi
                    Model -S2
                    Year - '96
                    KM's - 99,000
                    Engine Type - ABY
                    Engine Size - 2.2
                    Modifications -Standard
                    Driving style - Driven once a month sometimes at top speed for 5 min. Does less than 200km per year.
                    Currently running Audi issue oil unknown.
                    My other car
                    Make - Audi
                    Model - S4
                    Year - '2006
                    KM's - 110,000
                    Engine Type - V8
                    Engine Size - 4.2
                    Modifications - Standard
                    Driving style - Daily Driven
                    Car doesn’t smoke and does not use oil. Running Audi issue oil unknown.
                    My other other car
                    Make - Audi
                    Model - A4
                    Year - '2007
                    KM's - 110,000
                    Engine Type - ??
                    Engine Size - 2.0TFSI
                    Modifications - MTM chip and cat removed
                    Driving style - Spirited
                    orsum
                    • oilman
                      • Jan 2006
                      • 996
                      Hi
                      Sorry for the delay, had a week off.
                      In the S2, I'd go for a 15w-50 or 10w-50, depending on what you have available to you.
                      With the others, the safe option is a VW 504.00 oil, but depending on the service schedule you are using, a 5w-40 may be a good option if you like to put your foot down.
                      Tim
                      phone: 01209 202944
                      • orsum
                        • May 2010
                        • 1213
                        #311
                        orsum
                        • Billman
                          • 4129
                          #312
                          Hey Oilman,
                          what is the best oil that can take the abuse and last relative long (months/year-s) for a 2005 CBR600RR bike?
                          Go Holset or Go RS4
                          • oilman
                            • Jan 2006
                            • 996
                            An ester based 10w-40 is the best option for you
                            The UK's largest independent supplier of automotive oils, fluid and parts. We've products to suit any vehicle, from full blown Race / Track weapons, to Daily Drivers looking to save money. Plus FREE expert advice & recommendations - OPIE KNOW OILS
                            The ester oils there are the Silkolene Pro 4 and Comp 4, Motul 300v & 7100, and Redline.
                            Tim
                            phone: 01209 202944
                            • Billman
                              • 4129
                              #314
                              Thanks man!
                              Go Holset or Go RS4
                              • 94S2Sedan
                                • Jul 2012
                                • 77
                                • Home: United States Current: Brazil
                                #315
                                Audi
                                S2
                                1995
                                ABY
                                2.2
                                Stage 1 Performance chip, RS2 Intake manifold Dahalback Air intake, Full 3in turbo back exhaust no catalytic converters.
                                Around 300Hp
                                Southern Brazil 18-38 degrees average temperature
                                Driving style is quite aggressive anywhere from 500 to 1000 km driven per month
                                Currently using 10w 40 Motul
                                Thinking about switching to 5w30
