Volvo K24 turbo in audi application.
  • andy10v
    • 5996
    I'll make some chips specifically for this as well, and I'll give them to Paul, etc...
    Do you intend to do 3b stuff?
    Sold ABY-stock
    • prj
      • Mar 2010
      • 6308
      I am afraid not.
      I'll make the chipset on my own car, and that'll be ADU spec ECU.
        Originally posted by Rocco
        seeing these pictures we are lucky with 3B intake manifolds
        i believe to heard in the past something similar that the 3B intake flows better than ABY/RS2
        These results are not real world results as they are taken one cylinder at a time not all cylinders being measured at the same time which is what happens in an engine condition, therefore take them as a marker only
        • prj
          • Mar 2010
          • 6308
          • pnanassy
            • Dec 2004
            • 287
            • Country: Hungary
            #140
            Hi,
            do you mean the 56mm exducer version?
            Thanks,Peter
            Originally posted by prj
            K26 #6 hotside. Fits like a glove, very tight.
            As for the coldside, the easiest is to just cut and re-weld the exit. It's much cheaper and easier than other solutions.
            Peter Nanassy
            Custom Engine Management,and Electronic Fuel Injection solutions supplier , contact me for details.
            http://www.carstyling.hu/car_shower.php?id=19845
            http://www.youtube.com/watch?v=FYOVA_285Rs
            • prj
              • Mar 2010
              • 6308
              Originally posted by pnanassy
              Hi,
              Thanks,Peter
              Wasn't 56mm exducer on the K26 #8? If it is, then my logic would say it should be smaller.
              Then again, perhaps it'd be easier just to measure, because I might be wrong about the K26 #8 size.
              A source here:
              http://www.924board.org/viewtopic.php?t=15595
              Suggests that the minor bore of the K26 #6 is 48mm and the minor bore of the K26 #8 is 55mm.
              • Billman
                • 4129
                #142
                If it was with a turbine wheel with 55mm exducer it would be way laggier than K24-7000. 55mm is GT3076 territory.
                Go Holset or Go RS4
                • URQguy
                  • Sep 2008
                  • 245
                  Originally posted by Ross
                  This is a little bit unexpected... I would be interested to see an overlay with RS2 power as well; not so much for spool comparison - if it's pretty much K24 that is amazing - but for torque and power in the top half of the power band.
                  Rather than a ' hack and bolt on', what could be done to sort the aethetics of this ugly thing out? I see you've fitted the K26 hotside there - what hotside is that, where was it sourced? Do we think it would be possible to have a coldside machined to fit that looks/fits stock?
                  I'm trying to see how this could be used as a basis for a drop-in replacement on an RS2 to give 'the best of both worlds'...
                  I'll be in the Vegas-SLC area for 10 days early May, if it happens to coincinde with any more trips up there I would love to see this thing in the flesh
                  Ross
                  The K26 #6 is a direct bolt on with no other mods needed. They are the same turbine blade profile and size. I didn't think the turbos were ugly. Dave choose not to use the built in BOV on the turbo, but I would have. This is the same valve that Borg Warner is using on their top of the line EFR Ti Gamma turbos. They support huge power levels, and they are the same part number. I asked the rep at SEMA last fall. Really, the only ugly thing that can not be taken off is the raise in the casting and the volvo label.
                  Are you going to actually be in SLC?
                  Hank
                  1981 URQuattro with the TIAL GT35r.
                  2007 Infinity g35
                    Originally posted by Mcstiff
                    It is nearly worse than the 7a
                    ABY
                    The photo above is an ADU (RS2) intake. There are no ABY results unless the 3B and ABY intakes are the same.
                    • prj
                      • Mar 2010
                      • 6308
                      K24-7400 specs should be:
                      Compressor - OD 62mm, Inducer 45.8mm
                      Turbine - OD 59mm, Exducer 50mm
                      • Ruffiano
                        • Sep 2007
                        • 1458
                        #146
                        This is the only disadvantage - you'll have to get the intake fabbed up.
                        this was talking about the inlet hose for the turbo, 034 sells an off the shelf silicone replacement hose made for the larger compressor GT turbos with stock airbox, I'm fairly confident that this would be an easy answer.
                        http://www.034motorsport.com/turboch...ose-p-140.html
                        K26 #6 hotside. you could machine the coldside but part of the beauty of this is that it is modern technology, it is the "ETT" extended tip technology, although it might not be pretty it is functional.
                        Ross
                        Feel free to come check it out, PM me i'll give you my number and you can ring me when you are around. I was running an RS2 turbo with 034 software. this thing spanks it across the board.
                        ABY and ADU are identical. same castings, most ADU manifolds even have the square for the "powered by porsche" inscription.
                        • Ruffiano
                          • Sep 2007
                          • 1458
                          #147
                          And NCTS and hopefully not to start abidding war, but it has 2 days left and is going for 10 quid, it will probably go cheap since it is missing the hotside which means the volvo guys don't really want it... which means the Audi guys do
                          http://cgi.ebay.co.uk/Volvo-S60-T5-K...item41584706da
                          • a4kquattro
                            • Feb 2005
                            • 411
                            got a volvo part number on that turbo?
                            Marc Swanson
                            Proprietor, EFI Express
                            95.5 //S6 Avant
                            90' Coupe Quattro V8 4.2L twin turbo
                            93' //S4
                            83' UrQ
                            97' F250 7.3 diesel
                            • Ruffiano
                              • Sep 2007
                              • 1458
                              #149
                              5324 970 7400
                              Volvo Part number:8603298, click on the link below, there are several part numbers for the turbo, i believe the one i listed is for the "later" style with NON-vband outlet on the compressor side, the picture shows part number 30713137 which is also a valid number.
                              these guys sell new for 750
                              http://www.volvowholesaleparts.com
                              Just looked and it looks like the price might have gone up since 6 months ago when i last looked. However there is also this place, 900 including core charge:
                              • Jonas_R
                                • 3781
                                • Country: Denmark
                                #150
                                http://www.gt-motorsport.net/ also sells a MAF-turbo hose that will fit the wider outlet. He charges 135 euro for it.
                                Sleeper S2 Avant +450
                                A6 Avant 2.7t Stage 3
                                Audi S2 Coupe RS2'ed
