Audi Coupe OEM+ Interior Lighting Guide
This is a sticky topic.
  • Jas11n
    • 5067
    As promised;
    Bulb replacement in the mirror switch.
    Seen this question asked loads of times before, "how do you remove the inner door handle??" plenty of great explanations, but I can't remember coming across some good pictures documenting the process. So here's some of actually removing the inner door handle to gain access for removal of both the window switches and the mirror switch.
    Underneath the handle are three holes. The top and middle holes (numbers 1 & 2) contain an Allen headed bolt (some cars may have a torx headed bolt). You need a 4mm allen key, insert it up through the hole and fish about until you feel the allen key engage the bolt. Untighten them, not all the way as they are just clamps that clamp onto a bracket behind. Number 3 hole contains a pozi-headed screw, you need to remove this all the way out.
    Pull the handle away from the door card and slide out the switch panel;
    The window switch plate and the mirror switch plate and slide locked together, just simply slide them apart, either way, doesn't matter.
    Unplug the multiplug from the rear (same goes for the window switch plate if needed)
    Now you can take the parts you need into the house/garage/where ever.
    If your other half is up for it again, tie her up, gag her and remove all pets/children etc.
    Here's the switch still in it's plate.
    To remove, pull back on the two spring loaded hooks and get a blade down between the switch and the plate at the opposite end, push from the control side and out it pops.
    There's six tangs on the inner switch body holding it into the black outer casing. I carefully got a blade in where each tang is, then inserted a straightened paper clip to stop it snapping back. Did this on all six, then pulled back on the two spring loaded hooks again and withdrew the internal switch casing upwards.
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
    • Jas11n
      • 5067
      Make sure to leave the black switch body facing down (control buttons down) Once the innards come out you'll see why. There's two ball bearings which you don't want to lose. Put the black body to one side, it's not needed until you come to reassemble.
      This what you are left with;
      You need to lift up and remove the rubber cover which will expose the bulbs fully.
      Now you need to separate the circuit board away from the white plastic casing, just push the legs of the terminals out and they come apart.
      • Jas11n
        • 5067
        Here's the points on the PCB which you need to de-solder and withdraw the old bulbs from the other side. Old bulbs removed.
        Again, I choose this time to reuse filament bulbs, I'm not sure if the 3mm LED's would be bright enough, even though they are SB versions.
        The bulbs are again from Maplins, code >>> BT43W.
        They are a small wire terminal bulb, 12v 60mA and are perfect size for size replacement. I've used these in difflock, ATD and heated seat switch replacements.
        New bulbs soldered on.
        Then use a 12v power source to check you've made good solder joints,
        Reassembly is just a reverse of removal, REMEMBER not to turn the black casing upside down, you may lose those ball bearings.
        One last check to make sure reassembly didn't undo your hard work.
        Then go back to the car and refit it.
        Should now look like this. "Note" Dunno why, but I thought the two direction buttons were illuminated, but apparently not. The white "L" and "R" symbols are just painted on. Funny how you have a preconception about things
        Jase..
        • Jas11n
          • 5067
          Just realised this, inner door handle removal explanation above is for a Coupe, I'm not yet past it enough to own an avant (joke)
          If anyone doesn't think they are patient enough to replace any of these, get in touch. I'll replace them for you, all I ask is you pay for postage both ways
          • Acidburn
            • 13459
            think the avants handles are not much different from what i've seen of my avant.
            • A80Avant
              • 10873
              • Country: Greece
              #141
              jase i admire your electrical skills,you know that by now,so next job will be to fix the rear door window trigger light..only i would have to come to you as you have to take the doorcard out to reach the switch,which is different than the ordinary ones as it doesnt have a plug,it is completelly soldered with the cables...
              • YELL MAN
                • Dec 2005
                • 536
                • Country: Shetland Islands
                #142
                Wow now thats a good offer
                1994 Indigo Blue S2 coupe
                1994 80 Avant 1.9 TDI
                2005 Yamaha Fazer 1000
                1953 AJS Model 18S
                • Jas11n
                  • 5067
                  No problems Vasilis, you are always welcome. I'm around all weekend if you aren't up to much
                  Includes the difflock switch too
                  • A80Avant
                    • 10873
                    • Country: Greece
                    #144
                    Hmm...ill give you a call if there is time...
                    • Fat Audi 80
                      • 10547
                      Yes, you could regret that Jase!
                      Another storming write up, you make it look easy, but that is top quality. Great macro shots too!
                      The Perfectionist
                        Great stuff Jase, I've had a go at some of these in the past and they're a fiddle, its always the first one thats really tricky, when you find out about that spring that sends the small part into the far corner of the kitchen.. Good work, you're pointing out the pitfalls, I'm inspired to sort out some of my switches now. I particularly like the idea of illuminated door handles too.
                        • Jas11n
                          • 5067
                          Cheers chaps.
                          A big part is having the right gear, I know it may sound daft, but then you wouldn't go and try and change your turbo with a set of plastic mechano spanners and a torque wrench made from chocolate.
                          A good iron, 30watt is enough with a good fine pointed tip. No use trying to solder with an iron that gets as hot as a nuclear reactor and has a tip the size of a blunt cold chisel.
                          A de-solder pump is useful, a selection of small jewellers screwdrivers, a blade (swiss army knife for me) and a jewellers third hand is another tool that helps.
                          As John says, watch for the parts that want to have your eye out, the stalks on the steering column are büggers for that
                          I was going to have a bash at the door marker lights today on the S2, untill I got up.
                          A temp of -3 and snow showers........erm! I think not .
                          • Jas11n
                            • 5067
                            Right, finally got a bit of time to write this up. This is for the smaller buttoned switch.
                            Ever heard of the saying "If it ain't broke, don't fix it?"
                            I need to have that in mind next time. This exercise the other day cost me a diiflock circuit board. The things I do in the name of Audiness There was nothing wrong with my switch illumination, but after I finished there was.
                            First up, look at this picture below, look at it a good few times, even open it in another window, whatever. Just take note.
                            You are looking at the way the plastic block is screwed to the main body of the difflock unit.
                            When coming to reassemble your switch after you've replaced which ever blown bulbs, you CAN fit it 180° the other way. If you do this, and reconnect it to your wiring plug in the car, IT WILL blow the small black three legged transistor (I assume it's a transistor) and the circuit will be junk.
                            The block must be refitted exactly as shown below
                            Looked at the above picture??? Look again.
                            Right; First up, as said, I haven't got a run-through of the earlier large buttoned switch, I haven't got one to do a run-through on it.
                            Though the earlier versions drivetrain image is the same size, the push switch is a lot larger and is the same size as the switches on the dash.
                            If you want a later one, you'll need the rear centre console too, the oblong hole it fits in is a lot larger on the earlier consoles. The multiplugs on the rear of the earlier switch are different too.
                            There's two ways to remove it, it's up to you which way you do it. If you pick my way and damage it, don't blame me. Remove the rear centre console if you must.
                            I use a blade and carefully slot it under the front, then prise the front up;
                            Then do the same at the rear
                            Pull off the two multiplugs then remove from the car;
                            Remove the two screws and put the block to one side;
                            Now you can just lift up the circuit board;
                            Flip it over to reveal the bulbs. The yellow arrows point to the two bulbs that illuminate the drivetrain image, the green arrow points to the bulb that illuminates the green spot seen in the rear axle of the image when the difflock is on.
                            • Jas11n
                              • 5067
                              You can use one of two types of bulb for this. As you can see in mine, I used small wired bulbs from Maplins, code >>> PG77J
                              If you want the image to be slightly dimmer, the small bulbs used earlier in this thread for the mirror control switch are just as good.
                              Now, normally the text "DIFF" is illuminated at all times the car's ignition is on (the drivetrain image will only light with ignition AND lights).
                              If your text isn't illuminated, the red LED inside the push button will have gone. There's also a bulb inside that illuminates a yellow triangle behind the text. That will only illuminate when the difflock is on.
                              To remove the push button unit from the main body, get your blade and insert it down the side, gently lever the blade against it while pushing from the other side and it will come out from above;
                              Once it's out of the main body, again use your blade/tool to carefully lever up the main body from the tangs on the internal part, there's two either side;
                              The LED's used for the window switch illumination are again perfect for the replacing the LED in the push switch should you need to (CJ70M). You need to know which is the earth side of the LED (short leg of the LED), I've arrowed it below. If you are replacing this, then you'll need to junk the resistor in there, use a piece of thin wire to follow the old resistors route around the switch, or route the longer leg of the LED round the back
                              Here's what it should look like;
                              And when the difflock is on;
                              I'm sorry I've not shown any soldering of new bulbs, but as I said back at the beginning, my switch "was" ok as I'd done it way back when I bought the car years ago.
                              Big thanks to Sal for the replacement switch
                              [If someone has a spare earlier switch, or maybe a switch with duff illumination that they want fixing, let me know and I'll do a run-through for that too]
                                #150
                                Jase,
                                Just what I needed to know, thanks very much.
                                Kind regards.
