So some update. I find in some local shop a new O ring , so i buyed them 4 pieces and now is good, no leaks.
When i changed used bad O ring and whole servo oil was at engine bay for the firs time this day when i was went to the diagnostic this same day, so one mechanic change for another new ring, and did this for second time this day whole oil fill was in engine bay, lot of smoke and in that situation i hope that car catch fire
Than i order from Netherland 2 new X plugs, so i am happy, everything goes well with this seller ( i recommend http://www.autobedrijfvanderpol.nl/ )
Still ABS problem, i hate that but i do a new ABS ground connection on pump on different place, but i think that is good (better than before)
Now i want to check all 4 CV joints if there is right amount of teeth and same gaps between teeth.
I buy a spare plastic A, B, C pillars for making a new headline and with that i do cover pillars on the same material as headline
During winter i want to test spare door hinges, if the will be better than OEM old ones on the car
Any ideas how to remove broken plastic clips inside pillar trim?
