My Coupe project
    replied
    It's a hefty belt driven monster with a big tank but it recently sprung a pin hole
    My fault for not draining the water daily for some 20 years of ownership.
    Now, I thought I would treat myself to a new one but got a shock when I saw current prices
    So, despite knowing it's risky, I intend to fill the hole with weld
  • steve briance
    replied
    What sort of air supply are you using? As the owner of a proper lift, i imagine you have proper air as well...
    replied
    Originally posted by B5NUT
    I had a lot of dust issues with my cabinet, and it's all down to the massive amount of air your pumping into the cabinet. I upgrade (drilled another 50mm hole) my cabinet to have twin 50mm outlets and the dust has reduced by a massive amount. Also fitted some traps in the pipe work to catch some of the escaping shot.
    Brilliant
  • B5NUT
    replied
    replied
    Got my blasting cabinet set up.
    Works quite well but makes a lot of dust as the door seal isn’t brilliant.
    replied
    Originally posted by Bowie69
    Very good
    You are restrained in removing the seals, think I managed to just pry them out with a pry bar
    You painting the diff?
    Probably will
  • Bowie69
    replied
    Very good
    replied
    Quick update whilst I warm up having a tea break.
    There was a nice clear mark where the larger old seal sat. I put the new seal in to match. I used the old seal back to front to gently drift in the new seal.
    On the other side I used a 46mm socket and marked the position of the old seal.
    Then used it to drift in the new seal.
    This is how I removed the old seals.
    The flanges got a clean up and coat of zinc.
    Now torque settings. Set my wrench to 10nm. Once I reached that I re set to 25nm and went for the 90’. The 25nm was reached at about 80’. So, figure stated above appears correct. This was using new bolts lightly oiled.
  • SteveH
    replied
    I found no need for this tool, with a wiggle the input flange just came off.
  • Bowie69
    replied
    Originally posted by SteveH
    I need to do the input shaft seal on my diff, so I need to find VW 391 tool. Having taken a quick Google there doesn't appear to be many around for sale.
  • LSG
    replied
    Originally posted by Tractor Dave
    I didn't measure
    It was about 5mm inside the edge. There is a stop further in. So it doesn't go to the stop?
    Hopefully, there is a mark left where the old seal sat. Have you got the Bentley measurement?
    I did the seals on mine a fews years back now and didn't know not to pust the sael all the way in and guess what it leaked. Had to replace it a week later .. So do messure it fella. . Regards Lynn
  • SteveH
    replied
    replied
    Thanks very much. I don't plan on buying the tool. I managed without before.
    Not sure about 25nm? And 2.75ltrs of oil? Obviously refers to gearbox.
  • Bowie69
    replied
    OK here goes the Bentley pages for the diff seals:
    Screenshot 2022-01-05 at 21.13.04.jpg Screenshot 2022-01-05 at 21.13.56.jpg Screenshot 2022-01-05 at 21.14.18.jpg Screenshot 2022-01-05 at 21.14.27.jpg
    ....and a tool that has sold on ebay, with pics:
    Genuine VW AUDI SPECIAL TOOL 3066/1 mounting device for Sealing Ring | eBay
    Tool is 3066/1 for post 86 cars, and 3066/2 for pre 86, as noted here:
    Vag 3066 (c)http://www.s2-audi.co.uk
    With some other good pics, looks like the 3066/1 is deeper than the 3066/2.... so 8mm, maybe?
    Not sure if any of that actually helps!
  • Bowie69
    replied
    Hmm, perhaps, it is 3066 for the big seal, sorry!
