Fantastic work Dave. We really appreciate the photos and we know the time it takes to take them and post them.
My Coupe project
I got them from Autodoc.
I’m not keen on them but sometimes they have hard to find parts. They have 17mm centres which is much better than the puny originals.
Sent from my iPhone using TapatalkNothelle S2 Avant
Urs6 plus project goneComment
Steering rods came out nicely.
I made up heat shields for the area around the turbo and downpipe. The originals fell apart.
The driveshaft splash guards got repaired.
And fitted along with steering rod splash guards.
My rear bumper brackets fell apart when I removed the bumper. I managed to get a new pair.
Installed using stainless fittings.
I’m going to build up the front struts tomorrow.
All looking absolutely fantastic Dave, a credit to your attention to detail.
Autodoc.
This time around have got quite a few parts from them which were hard to find or very expensive in the UK. Lemforder steering arm ball joints, drop links and Koni shocks also from them.
Their after sales service is very poor but if you double check what you are buying to make sure it fits and decline any replacements they may offer, recently everything has been good.Nothelle S2 Avant
Struts all together and fitted on the car.
I’ve used Lago Blue’s strut mount savers again. They are still going strong on the Avant after a few years and it seems a no brainier not to use them when doing this job. Easy to fit, reasonable price and detailed instructions (unlike Koni). What’s not to like?
Back brakes all done. New Brembo discs and pads. Calipers and carriers overhauled, new bolts.
I had to replace one abs sensor that didn’t survive earth re entry. I picked up one on eBay for a good price but had to swap the plug over as it was different. I tied string to the old one before pulling it through to aid fitting the new one.
I replaced all the cages and used ceramic grease (non conducive) to reduce corrosion and aid future removal.
I made a start fitting the exhaust. These are the cats that were on my Avant as one cat was missing and one had nothing inside. I fitted RS2 cats on the Avant.
