A little something to keep me busy
  • Rikki Kitto
    • Feb 2010
    • 6276
    Draper probably have all there stuff made in China now like most things
      • Dec 2017
      • 5984
      It might be a fake. I've been watching you tube videos and others recommend the Draper but I've noticed a few small differences. I bought it on ebay a while back so unfortunately I'm stuffed.
      • Rikki Kitto
        • Feb 2010
        • 6276
        It's crazy how fast they rip stuff off I bought 3 044 fuel pumps the 4th was genuine
        • B5NUT
          • Sep 2021
          • 1071
          Have to say I don't think much of draper these days. I got an 8mm punch and die for my vice mount flaring tool and it works very well. However it's not much use if you need to do it on the car. Doing some nice work Dave. Just hope it's well looked after if it goes back to it's old owner.
            • Dec 2017
            • 5984
            Sometimes you have a good day and everything goes to plan.
            I took the pipes cut to length to my tractor mechanic friend. He has a Sykes tool and made perfect flares on the pipes in under 5 minutes!
            I then set about fitting them (hoping I hadn't got the lengths wrong).
            All was good and everything went together nicely.
            Next job is to re fit the heat shields.
            They all got a good scrub.
              • Dec 2017
              • 5984
              Looking at my pics I think I need to invest in or make an 8mm pipe straightener tool
              • B5NUT
                • Sep 2021
                • 1071
                It's not that bad seeing as you have done it by hand, but I do use the Kwix tools they do a very good job.
                  • Dec 2017
                  • 5984
                  Thanks for the heads up. I will see how much they are.
                  The remaining brake lines were good but the plastic coating had some damage.
                  They got rubbed down and painted with epoxy.
                  Then the rear driveshafts were finished off with the new cv joints.
                  Onto the rear diff. Old bush removed and housing cleaned up ready for the new polybush.
                  Input flange got cleaned ready for paint.
                  And output shaft seals got changed.
                  The big one was a sod to get out but easy to put in. I managed to get this from Tradition. Seems to be the only place selling them now?
                  I just need to put some fresh oil in then it's more or less done.
                  • steve briance
                    • Aug 2014
                    • 1455
                    I made this pipe straightener when i decided i didnt want to spend the money on the kwix tool. They really are the business but a bit too much for me and the amount of pipes i make.
                    My design sort of copies the principle and worked pretty much as well. Keep working pipe back and forth and rotating it - the rotating action replicates the action of 4 rows of rollers but with just 2.
                    This gallery has 1 photos.
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      Diff Bush removal looks a bit brutal, well done on getting it out
                      • B5NUT
                        • Sep 2021
                        • 1071
                        When it all goes wrong you can always count on a BFH
                          • Dec 2017
                          • 5984
                          It had well and truly welded itself in there. Fold the lip over with old blunt wood chisel then using large drift hit it like f##k in the right direction
                            • Dec 2017
                            • 5984
                            Apparently my bushes are coming from Verkline tomorrow.
                            I made a start getting things together.
                            And cleaned up the many bolts, most of which are nla from Audi.
                            They will get treated and painted.
                            • Rikki Kitto
                              • Feb 2010
                              • 6276
                              Amazing these are all now NLA, Audi are truly rubbish in this respect
                                • Dec 2017
                                • 5984
                                It's a nice sunny day and perfect for zinc paint.
                                If you remember a couple of weeks back my Dewalt drill fell apart whilst drilling out bushes. I got a replacement within 24hrs from FFX but realised it was still under the 3 year warranty with Dewalt. They collected it last week and it came back today. Amazing service. Works perfectly. Now I have a spare.
                                Straight away I put it to good use drilling out the old cut off bolt in the hub carrier.
                                Then tapped in new threads.
                                Unfortunately Error isn't going to have any billet connectors in time for this project so I got a Vaico one. Audi version is nla and only other option is topran which I wouldn't trust. The Vaico looks sturdy and fits well.
                                My bushes never turned up yesterday. DPD are not very reliable anymore around here. Sad face.
