Black Ur Project
  • 4WDrifter
    • Nov 2012
    • 1251
    #166
    I was as bad on the other side lol
    1996 S2 ABY Coupe silver
    2003 S3 8L dolphin grey
    2014 RS4 B8 prism silver
    • 4WDrifter
      • Nov 2012
      • 1251
      #167
      • 4WDrifter
        • Nov 2012
        • 1251
        #168
          • Dec 2017
          • 5999
          I've been putting this job off as it's my least favourite.
          Cleaning the underside. ;(
          So just got stuck in over the weekend.
          Front arches are very good.
          Just a little patch of surface rust at the end of the sill.
          And the odd stone chip.
          Sill cleaned up and just needs treating and painting.
          Generally, underneath is excellent. When I have cleaned everything, treated any rust spots and painted, everything will get a fresh coat of dinitrol 447 which conveniently is black.
          • steverrquattro
            • Oct 2006
            • 788
            Can you show the products that you are using to treat and paint over any rusty bits.
            Steve
            1990 RR 20V
            1982 SWB UR - RS2 Engine
              • Dec 2017
              • 5999
              Sure. Will do.
              • K Simmonds
                • Dec 2007
                • 7627
                That's a nice MIG.
                1990 B3 2.0 80 quattro.
                1992 C4 2.8 Avant quattro
                1994 MTM RS2.
                1998 B5 TDI quattro Sport.
                2000 B5 TQS.
                  • Dec 2017
                  • 5999
                  The hard work goes on.
                  I made this tool which is handy for the nooks and crannies.
                  I'm finding very little rust which is a bonus.
                  • K Simmonds
                    • Dec 2007
                    • 7627
                    That's looking really good, the lack of rust is really outstanding for a B2 chassis car.
                    I've made a couple of wirebrush extensions for drill's, very handy for getting into the tight spots.
                    1994 MTM RS2.
                    2000 B5 TQS.
                      • Dec 2017
                      • 5999
                      So, after almost a week of work, the underside is almost done.
                      Some rusty spots were cleaned right back to good metal and treated with Bilt.
                      I put a small amount in a clean jam jar and use it from there. You can't put your brush in the main bottle as it contaminates it slowly.
                      Where the rust is between seams, I clean back as best as possible and use this. Fertan seeps into the seams and works really well in difficult spots.
                      Now, onto prep. I need to de grease everything ready for fresh underseal.
                      I like this.
                      Sprayed on pre mixed and a good scrub with washing up brush. Then rinse with warm water.
                      Crazy humid here in west Wales today so I won't be doing any painting for a while.
                        • Dec 2017
                        • 5999
                        Had a push this afternoon and got all the prep done.
                        This bit behind the battery box is almost impossible to clean. Did my best.
                        Unfortunately a stone chip on the sill has spread into the paintwork.
                        Now I just need to heat the garage up and move onto the painting stage.
                        • 4WDrifter
                          • Nov 2012
                          • 1251
                          #177
                          Great progress Dave. How’s the back holding up?
                            • Dec 2017
                            • 5999
                            Not too bad thanks. Stiff neck last night after looking up all day
                              • Dec 2017
                              • 5999
                              Next chapter.
                                • Dec 2017
                                • 5999
                                Anyone done a servo conversion on an early Ur?
                                What pump to rack pipe can I use?
                                Servo recommendations?
