Another "Stroker" Project
  • Billman
    • 4129
    #241
    Originally posted by Bram
    twin scroll turbo???? That must be laggy What are your expectations of spool-up and max power?
    Hehe.....2 bar at 4000 rpm on 3. gear would be nice and 500-550 if it works well! :-D
    Go Holset or Go RS4
    • Billman
      • 4129
      #242
      minor updates
      Go Holset or Go RS4
      • A80Avant
        • 10873
        • Country: Greece
        #243
        you have missed a bolt...
        aaah reminds me of something those pics...
        • Billman
          • 4129
          #244
          nope...there's no hole.... :-p
          Go Holset or Go RS4
          • A80Avant
            • 10873
            • Country: Greece
            #245
            oh well...
            lets see how youll get on with it!
            • quattro84
              • Mar 2006
              • 947
              Indeed.. let's see what that baby is gonna push!
              • Billman
                • 4129
                #247
                Question: What cam belt covers do you use with the strokers?
                Go Holset or Go RS4
                • Billman
                  • 4129
                  #248
                  Some Input please!!!
                  Go Holset or Go RS4
                  • Rocco
                    • Aug 2007
                    • 6393
                    • Country: Spain
                    #249
                    if the original from 2.2 it is not valid...may the original from A6 2.5tdi could fit
                    and if not..dont use it
                    good luck¡
                    • Billman
                      • 4129
                      #250
                      i thought about it but i was hoping for something more precise! ;-)
                      Go Holset or Go RS4
                      • Billman
                        • 4129
                        #251
                        put the head on today!!! ARP bolted till 95 ft/lbs
                        For now the timing is off but i am going to sort it out.
                        Go Holset or Go RS4
                        • caterpillar
                          • 2480
                          #252
                          niiice projekt.... think you will like the new engine, and the torque(!!!!!)
                          • Billman
                            • 4129
                            #253
                            Small update and a question: Thick blue line on the "A" side is stock position. In order to advance the exhaust cam by 5 degrees how much do i need to move it further to the A side, 2,5 degrees?
                            Go Holset or Go RS4
                            • GT500
                              • Jun 2006
                              • 2181
                              If you want 5 degrees move it 5! The double speed of the cams to crank dosen't come in in to it.
                              MOve it 5 and re check it'll be 5 different.
                              HTH
                              Rob..
                              87 UR 20v ABY
                              97 S6 Avant
                              • Billman
                                • 4129
                                #255
                                I need to find a starting point for the cam settings on the stroker. Both cams are 7A.
                                As i read the stroker topics there is said that due to the difference on deck height the cams are 5 degrees advanced. Does this mean i can simply put it on the marks and start from there?
                                Go Holset or Go RS4
