My 3B Coupé Project.
  • terrybullwon
    • Mar 2006
    • 8782
    Originally posted by Acidburn
    Lol not far from me was it expensive?
    Ring him, hes a friendly chap... Good for a waffle
    Stu, looking good! What spec clutch is that?
    Chef
    • 4WheelDrifter
      • Oct 2004
      • 5773
      • Country: Devon
      #77
      What? The box of parts? Yes very. I drove pretty carefully on the way home. The 440+ miles I travelled to get the parts there and back didn't come cheap either. But I felt safer delivering it myself.
      Obviously the cost of the balancing depends on what work you have done. As already said, give Phil a ring, he's a friendly chap.
      Bo - Thanks for your help on the crank.
      James - It's a Spec 3+ pressure plate and a Clutchnet Carbon friction plate. I got it from Aelred when Clutchnet apparently didn't have any pressure plates, so he got a batch from Spec, but I still wanted to have a Clutchnet clutch to replace the one that Bo had.
      SS
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        #78
        Here's another picture of my crank, minus ~1.4 kg.
        SS
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          #79
          Here's my block.
          I admit it's not the best paint job I've ever done. But in my defence I did paint it at about 2am on Christmas day on my return from the pub. It seemed like a good idea at the time.
          I spent most of yesterday morning giving the block a good clean inside, tapping all of the bolt holes, and poking brushes down all sorts of places to get any dirt out. The oil return from the breather was almost completely clogged.
          SS
          • s2_bo
            • Oct 2005
            • 6067
            #80
            Nice one stu. Im looking forward to seeing your progress on this. Are you gonna fit it back in this coming Christmas at 2am then?
            91 S2 coupé - RIP
            98 S8 - Luxury barge
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              #81
              How much detail do you want to see on the progress? I've taken a few pictures, which seems to take up more time than actually putting the engine together.
              SS
              • volcano rs
                • Jun 2005
                • 2265
                no excuses we want more pics :mischeif:
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  #83
                  New oil non-return valve, adapter and squirters.
                  Squirters and main bearing shells installed.
                  Mains lubed.
                  Crank fitted.
                  SS
                  • volcano rs
                    • Jun 2005
                    • 2265
                    looking good keep it up
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      #85
                      Checking the bearing clearances.
                      Not too bad for an old crank.
                      SS
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        #86
                        Main bearing caps fitted with new bolts torqued to 65 Nm.
                        SS
                        • s2driveruk
                          • 12696
                          looking very good there Stu.......kinda wishing i had taken more time over mine and cracked it open now
                          1992 3b S2 Coupe
                          • 4WheelDrifter
                            • Oct 2004
                            • 5773
                            • Country: Devon
                            #88
                            Checking the top ring gap.
                            And the 2nd ring gap.
                            SS
                            • 4WheelDrifter
                              • Oct 2004
                              • 5773
                              • Country: Devon
                              #89
                              Just whip the engine out again if you get bored over the Christmas break.
                              SS
                              • 4WheelDrifter
                                • Oct 2004
                                • 5773
                                • Country: Devon
                                #90
                                I got 4 sets of Mahle piston rings from GSF and 1 set from Audi, which cost almost as much as the 4 GSF rings.
                                The top 2 rings seem to be the same, but the bottom oil ring is different.
                                Here are the Audi piston rings with a 2 piece oil ring.
                                Here are the Mahle piston rings with a 3 piece oil ring.
                                Here are the pistons, rings and rods assembled.
                                SS
