RS2 America
This is a sticky topic.
  • Once I have the proper measurements I would like to take the intercooler to the machine shop and have them machine the inlet for the correct fit. Heating it a great idea though. I will keep that in my back pocket.
    • I make it 51mm/49mm.
      Where 51mm is the lead in or whatever you want to call it and 49mm is the diameter behind it. Measurements are from a used item which might not be still round so I have averaged it!
      Swage!
      • that hose is from venair so i take it its not the orginal one?
        • Originally posted by twoqu View Post
          Thank you. That is what I needed.
          • Originally posted by rxl View Post
            The Venair hose is the factory hose. It is exclusive to the RS2. Part number 034 145 746 BC.
            • Does the excess WGFV (N75) wiring just lay underneath the air box inlet? The wiring does not appear to be long enough to travel around the air box inlet.
              I am also in need of the part number for the white clip that holds the connector to the rail.
              • Originally posted by saltinot View Post
                Anyone know the answer to the above questions?
                • Yes I think it does from memory as you have the cover piece for the lighting shroud that fits next to the air inlet too.
                    There’s someone on the Facebook page getting those clips made, black ABS though
                    • Cheers guys.
                      Greg, you mentioned a cover piece. Am I missing a part?
                      After some digging I came up with 443 972 614 as the number for the white clip that secures the grey N75 connector (seen at the very bottom of the picture above). I never found a picture of it online. They run about 4USD so I will take a gamble and see what I get.
                        Cheers guys.
                        • Rxl, where did you get that intake hose from?
                          • Originally posted by andersg View Post
                            roose motorsports... its the vintage black finish. have all the hoses from them.
                            • I have theese they look great and the wrap helps with the clips not slipping too
                              • Update? Is this done yet?
