My 3B Coupe project - Total rebuild
This is a sticky topic.
  • terrybullwon
    • Mar 2006
    • 8782
    thats if the engine is able to turn of course
    Chef
    • volcano rs
      • Jun 2005
      • 2265
      sorry to hear that andy
      • A80Avant
        • 10873
        • Country: Greece
        #228
        come on andy, you have a deadline on october 9th. Dont go Jamo on us now!!!
          You what?
          • A80Avant
            • 10873
            • Country: Greece
            #230
            meaning taking 2 years to make it work!
            just joking of course
              You'll find it also took Andy just over 2 years to make his work if you look at the start date of his project, anyhow
              • A80Avant
                • 10873
                • Country: Greece
                #232
                oh nooooooo
                its a curse!!!
                jokes aside Andy, you can make it work! its worth it. If i had any money left i would go for a stroker as well. Now my way future plan is to go for an rs2 sedan.
                • Acidburn
                  • 13459
                  sorry to hear about this andy, hope you getting it sorted,was looking forward to seeing this at adi
                  • AndyP
                    • 6049
                    The mustery deepens, and so does the sinking feeling in my stomach
                    First off a massive thanks to quattro Dan for getting the car back into the garage, an 8ft scaffolding pole and a T30 transporter van did the trick nicely
                    Initail findings:-
                    - The engine will not turn over
                    - It's not the cam pulley, that was still locked in place and the keyway in tact.
                    - Everything under the cam cover looks OK
                    - The cams and valve train will turn easily and are now set back to TDC on No.1
                    - Looking down the inlet tracts there is no obvious signs that the valves are bent.
                    - With the cambelt off I can turn the bottom end backwards and forwards by about 10° before it reaches a very solid, metallic stop
                    - Number 3 spark plug is stuck solid. Others came out normally and look OK.
                    - Looking down no.1 & 2 spark plug holes I can see what looks like metallic debris
                    That was enough to ruin my evening so I'll pull the head tomorrow to reveal the full horrors beneath.
                      Originally posted by AndyP
                      The stroker is no more
                      Oh f**k!!
                      Really sorry to hear this
                      • AndyP
                        • 6049
                        I can't see this being fixed for ADI
                        Still not sure what has caused this yet. If the timing had slipped would you expect to see marks on more that one piston? becaue the other pistons and valves appear untouched.
                        I'm going to pull the bottom end out tomorrow night and see if there is anything in there that could of caused it
                          You must be devastated dude.
                          has the valve stem snapped? I have a good 3B head if its of any use?
                          • AndyP
                            • 6049
                            Yes valve snapped clean off
                            I'm suprisingly calm actually, already planning on what I need to re-build it
                            • A80Avant
                              • 10873
                              • Country: Greece
                              #239
                              thats pretty awfull. I agree with error, could it be that a valve snapped or something?
                                what are the chances?
                                Is the bore ok?
