Project: RS2 ABY
Andy,
As discussed yesteray - if there's enough room to clear the subframe, space the passenger engine mount down with a few washers and that should give the extra 4-5mm needed to hopefully clear it!
I have an 034 Motorsport snub mount you can have. Let me know if you need it popped in the post. Just be aware, that the intense vibration transmitted through the chassis is against the grain of the fabric you are weaving... it's a snug fit though so grinding a few mm off it's diameter would probably solve the vibration under normal operating conditions (ie not WOT and full boost).
Cheers,
RossAUDI - saving Dad's from minivans since 1994
@Sonic have you spoken to Rich yet to see if he has made any headway? Might be worth discussing the option of lowering the mount before he starts cutting bonnet!Haynes Manual:As described in Chapter 7...
Translation:That'll teach you not to read through before you start, now you are looking at scarey photos of the inside of a gearbox.Comment
Bonnet idea is a good one...
Best of luck sorting out your problems Andy.
I know it is an obvious point but I feel better having posted it: Don't go round the ring if there is ANY chance of the throttle jamming open again, it is potentailly lethal!
Cheers,
Steve.The Perfectionist
- nothing like a pre-ring challenge.
