3b s2 coupe resurrection
  • andy10v
    replied
    Fresh battery, no start.
    Starter clunks but does not spin
    Removed starter and checked operation, works ok
    Cleaned starter contacts
    Car starts (MAF sensor unplugged as leak testing)
    Leak test
    Intake manifold still hitting power steering pump bracket
    Clearance power steering pump bracket
    Tighten intake manifold
    Leak test, now holding 30psi
    Refit MAF
    Car does not start (engine spinning over)
    Unplug MAf
    No signs of firing when spinning, almost fired a couple of times as I let go of the starter and throttle.
    Fuel gauge is showing just above the red, so I am going to get some fuel and then try again.
  • andy10v
    replied
    I have TFSI coils, 06E 905 115E
    These ones need trimmed as per Dave
    Should mine be trimmed?
  • andy10v
    replied
    Random thought, should I have trimmed those coil packs to make them sit down further?
  • andy10v
    replied
    Injector kit + spare seals
    Removing injector filter
    Old filter v new
    Removing pintle cap with a trim tool
    New o rings, filter, spacer and cap
    Back together
    Fitted the injectors with the new seals, same leaks, fitted the blue seals instead and less leaks, gave them a wiggle whilst under pressure and they stopped leaking.
    Fired the car up, had to use the throttle, sounds silky smooth at 2k+, wont idle, sounds like its not running on all cylinders at low RPM. Took it for a drive, drives perfectly at part throttle if kept above 2k, bogs below that, goes great as it starts to build boost, falls flat on its face about 5psi, feels like a boost leak and goes rich.
    Drove back home and then it died about 10 times in a row trying to manoeuvre into the drive, eventually would not start (battery voltage dropped), winched it back into the garage and left it in disgust.
    So tomorrow after work its boost leak test, pull codes, check over and hope for the best. (battery on charge tonight)
  • bunyoch
    replied
    Weel weel bluidy brakes at laast ----guid ! -- thet should be fair helpin tae keep ye oan the black stuff --- an nae mair burlin lik a peerie doon yon wee brae wi yer haunbrake staunin lik a sper prik et a hoor's weddin !
  • K Simmonds
    replied
    Well done that man, really glad it's worked first try, testament to Alex's proficiency with the looms and your attention to detail.
  • andy10v
    replied
    Thanks, Knockhill on Friday, so no pressure
  • Michael S2
    replied
    Impressive work as always. Whens the next track day Andy?
  • martinws
    replied
    Good job, ano spares are useful. I think it's probably just driving in a big circle at up to 130mph for.hhours on end that has done the tyres in. My RSRs are pretty melted looking.
  • andy10v
    replied
    Injector O rings have been ordered from 2 sources, both due tomorrow to cover any delays, spares will not go amiss anyway.
    Brakes bled, flushed through 1L of Motul RBF 600
    Took pity on one of the wheels, brake dust is pish to get off
    This is the NSF tire, the outer edge is feathered as you would expect, the middle is also feather at an angle, is this when the tyre has got too hot, ballooned and then pretended to be a motorbike tyre?
    I also weighed my wheels out of curiosity;
    16x7.5 avus 205/55/16 16.7kg
    17x8 avus 234/45/17 21.8kg
    17x8 BBS RX 235/45/17 21.8kg
  • andy10v
    replied
    Perfect, thanks
  • AndyP
    replied
    Originally posted by andy10v
    Any info on injector o ring size or sources?
    http://www.ebay.co.uk/itm/Audi-5-cyl...item25a200aafd
  • andy10v
    replied
    Are the o rings genric bosch ones?
    I have used petroleum jelly as lube, is that recommended?
    replied
    Yes fit new o rings and use lots of lube
    replied
    Wagner IM has no inserts
