3b s2 coupe resurrection
  • andy10v
    replied
    Intake manifold off, wagner offered up for a test fit, hits the power steering pump as expected, shorter belt on order.
    Next problem
    Injectors in fuel rail and the front of the injector hits the intake manifold;
    Injectors in intake manifold
  • andy10v
    replied
    Originally posted by martinws
    Ps. Do you think that with a bit of heat on the aluminium and water running through the stainless cam cover pipe you could pull it right out the back? Or is it all one piece?
    The long pipe is alloy, I didnt check what the ends are. I think remember reading that you can just twist the front one and pull it out.
  • andy10v
    replied
    I'm going to do the very same thing with breather pipe. I have a stainless water separator that I'll put more baffles in with possibly a swirl pot or bmw vortex thing before it. Are you blocking the front or back of the new head breather or venting both sides?
    I have blocked the front just now and will vent out the rear, could do some experimenting into coke bottles to see what is the best?
  • martinws
    replied
  • martinws
    replied
  • andy10v
    replied
    New breather setup will be
    Crank breather to old head breather
    Modified pipe through the head will be the vent
    New cam vent to swirl pot
    Swirl pot drain to sump (below oil level)
    Swirl pot vent to catch tank
    The block will vent through the oil drain holes into the head, and also from the block breather into the stock head breather. The head will vent out the modified pipe in the cam cover. This is to combat oil surging out the block breather on hard right hand bends, out out the back of the head breather under hard acceleration. I am not sure if it is best to link the head and block via the stock breathers or not? I know Hank Iroz vented out just the head at 600bhp, relying on the oil drains for crank case ventilation and had no crank case pressure build up. Will oil slosh between the head and the crank case? Does it matter or would they be better blocked?
  • andy10v
    replied
    Cam cover off again, head stud torque checked
    New gasket on modified AAN cam cover
    Coils on
    Stuck now as I need a new throttle body gasket, also the throttle body hits the AAN cam cover, so I guess its wagner time! I also need to take the radiator out to modify my breather setup.
    So new plan is;
    wagner intake
    ABY fuel rail
    make boost hose from intercooler to throttle body
    make ISV extension pipe
    fit swirl pot
    new breather setup
    Also adjustable top mounts arrived
  • andy10v
    replied
    Originally posted by Error404
    Oh **** I forgot about that VSS signal wire!
    I will do it tonight
    I had just assumed I had lost it.
    Does it need VSS anyway?
    replied
    replied
    Hope so
  • andy10v
    replied
    Yup, it was perfect Alex, thanks again
    Thanks gents, hopefully it fires right up and it will all seem worthwhile.
  • zafra
    replied
    +1000
  • K Simmonds
    replied
    Watching your progress with great interest, nice one for taking the time for pic's and writing up what's involved
    Hope it all goes smoothly from here!
    replied
    Cool, so that connector was a straight fit into the 3B harness?
  • andy10v
    replied
    I will answer that once it starts
