3b s2 coupe resurrection
  • andy10v
    replied
    Any reason? I guess fuel pressure regulator is more available for ABY clip in?
    replied
    Yep, although I switched to an ABY fuel rail while I was at it
  • andy10v
    replied
    Originally posted by andy10v
    Current plan is
    ABY ecu conversion with coils
    check everything works
    Fit wagner intake manifold
    remove gearbox
    remove downpipe
    fit new turbo
    fit clutch
    refit gearbox
    make new downpipe
    fit exhaust
    fit pressure side maf
    fit eboost
    check car runs on low boost
    drive to Automark, fit 440 injectors
    Live map
    Any suggestions/flaws in my cunning plan?
    Also have an AAN valve cover coming
    I presume I can continue to use the 7a fpr as it is 4 bar same as ABY?
    replied
  • andy10v
    replied
    Originally posted by newsh
    What EM?
    RS2 style one I got from quattro nick is already fitted
    replied
    What EM?
  • andy10v
    replied
    Cool, thanks.
    Got a bit of stuff organised/ordered.
    RS2d ABY ecu organised (thanks to spink)
    COP 3b conversion loom organised (thanks to error404)
    Metal maf tube organised (thanks to tomwood_uk)
    SRE clutch ordered
    Current plan is
    remove gearbox
    remove downpipe
    fit new turbo
    fit clutch
    refit gearbox
    make new downpipe
    fit exhaust
    fit eboost
    Live map
  • quattro-nick
    replied
    Remove the tie rods on the steering gear to make more room
  • andy10v
    replied
    I have never done a clutch with the engine in, I assume it should go
    unbolt;
    downpipe
    prop
    driveshafts
    gear linkage
    procon 10 cables (going to be a PITA?)
    clutch slave
    gearbox mounts
    and pop the gearbox out
    Any tips or suggestions?
  • andy10v
    replied
    Originally posted by Wizard-of-OD
    And wideband!
    ST3402 available in white face. Looks almost the same as a VDO unit from Audi!
    Too bad VDO don't make a wideband guage.
    http://www.stackltd.com/instruments.html
    Wideband was installed a couple of months ago (AEM), boost guage is Rusty's stock look gauge, EGT is an ebay special
  • Wizard-of-OD
    replied
    Also to get an eboost street for boost control.
    And wideband!
    These precision auxiliary instruments combine digital microprocessor accuracy with a high precision stepper motor needle movement to provide a new level of accuracy and reliability in 52mm gauges. All gauges come complete with wiring harness and associated sensor.
  • andy10v
    replied
    Thanks Nick, but I dont have the time to learn VEMS, though it is tempting.
    I emailed Mark my spec list for him to look over last night and he called to discuss today. If I want a hassle free mapping session he said to fit the ABY ECU setup and there is no potential for lead breakdown, spark hop etc. Also to get an eboost street for boost control.
    So I need
    ABY ECU
    coils
    coil loom
    ABY cam cover
    eboost street
  • quattro-nick
    replied
    i use also vems,bought a plug&play kit from efi express with wideband, egt sensor and vems round wideband gauge,cool stuff
    this is the first time I've programmed a standalone ECU in my car
    the ECU was provided with a program that the engine could be started with
    the rest i programmed myself,i just try a few things(with my own knowledge) and see what the results ware
    it is provided with a "LIVE VE ANALYSER", this is a self-learning program for you ve table,very easy to use
    you also find enough support on the internet or forums
    i have no experience with other standalone ecu"s
    http://www.efiexpress.com/catalog/
  • andy10v
    replied
    Originally posted by K Simmonds
    Thought it would be one of Albert's, the performance looks really impressive and being a K26 they should be tough as old boots. I'll be very interested to see how you get on with yours, I may still take the plunge myself even though I'm happy with my current set up.
    I reckon there's enough space between the wings for a custom airbox, I did think about doing that myself when I had a cone filter fitted.
    Hmm, that's got me thinking I could sell my RS2 airbox if I did that.
    Yep, VEMS is only appealing if your can map it yourself, I don't have either the IT or tuning know how to even make a start, guess it's just a case of learning but the cost if you make a mistake could be silly
    Yup, I dont want a garret with amazing spool ******** itself every other year. They also dont deal well with over spinning (eg pop a boost hose etc)
    My current set up is great, but I want it mapped so its "free" (man maths, buy the billet k26 and sell the rs2). More powah is always better
    I dont have time for another hobby, I want to fit the bits and wail on the car, not tune it. Also as you say it would be easy to ruin it all.
  • K Simmonds
    replied
