3b s2 coupe resurrection
    replied
    Yeah I can help you out mate, drop me a PM when you're ready
  • andy10v
    replied
    Originally posted by Error404
    Queer or summat?
    Rack is going to be a bitch, box out will make life easier for sure. I would go to ABY ECU . More expensive than the dizzy setup but less pissing about once it's installed and more reliable long term
    From the looks of Alberts dyno chart you shouldn't loose much if any response
    Poly bush everything, makes a huge difference. Unplugging the N75 will improve your driving, help you learn to carry more speed
    Thanks for the sanity check
    Would you make a COP loom like your current one but with long wires for ecu coil signal and dizzy hall or whatever you do with the coil?
  • andy10v
    replied
    Originally posted by newsh
    I did mine when the turbo and downpipe were out. Having the battery tray removed is a serious help too.
    Cool, I will have the down pipe out as well
    replied
    Originally posted by andy10v
    So do I want 370bhp or 450bhp?
    Queer or summat?
    replied
  • andy10v
    replied
    Straight swap as Steve says, but 2.6 turns v 2.8 lock to lock. ABY rack feels lighter than the 3B with the servotronic off.
    Not great access to swap it, Kit did it with the IM off, Alex did it in situ, I will have the gearbox out so should be easier, battery tray is cut out so should help.
  • SteveH
    replied
    Originally posted by supersonic112
    Would be keen to know how easy it's to swap a 3b rack for an Aby. Is it a straight swap or do you need other parts on top?
    It's identical, so a direct fit. With the exception of the servotronic electrical connector.
  • supersonic112
    replied
  • andy10v
    replied
    So current winter plans
    Fit wagner intake
    Fit 3" exhaust
    Replace MFTS with VDO sender
    remap
    cam cover vents/baffles (time for something that welds alloy?)
    I am adding to the list
    SRE clutch
    ABY rack (easier with the box out?)
    Might as well drop the front subframe at the same time to alloy bush, replace all wishbones with poly and get an alignment done.
    Anything else whilst I am in there?
    I am torn on turbos, I can buy Albert's turbo and sell the RS2, so should not cost any money, I will be getting a live map either way and already have bigger injectors.
    So do I want 370bhp or 450bhp? (I am concerned the billet k26 with a modified exhaust turbine may not be as nice to drive?) Any opinions from folk that have gone up from RS2 spec?
    Also do I go COP so 100% no misfires?
  • sjw185
    replied
    I think Martin is booked on for Sat 28th of February (track Scotland day), is 11th of January a Knockhill trackday?
    I imagine it is going to be pretty cold and wet either day
    Seen the 11th mentioned in earlier post?, I'm home around the 28th so will try and get booked.
    Got some of this brake fluid for flushing system
    The UK's largest independent supplier of automotive oils, fluid and parts. We've products to suit any vehicle, from full blown Race / Track weapons, to Daily Drivers looking to save money. Plus FREE expert advice & recommendations - OPIE KNOW OILS
    Got some old progressive springs off the coupe, think they are Koni if you are interested?
  • andy10v
    replied
    Your car did look like it was trying to wheelie most of the way up the straight!
    Proper brake fluid should hopefully sort the brakes, but yeah no load on them in the wet.
    Unplugging the N75 would probably be very good for smoothing me out.
  • martinws
    replied
    PS. I highly recommend unplugging your n75 for a few laps just for a giggle.
  • martinws
    replied
    My federal RSRs seemed to do a fair job. I'm in desperate need of stiffer springs for the 90. I run koni adjustables and stock s2 springs. It bottoms out at the bottom of the chicane and has some serious reverse rake even when parked up.
    At least if February is wet n cold, your brakes might last longer.
  • andy10v
    replied
    Originally posted by sjw185
    Yea offshore at the moment.
    Have not checked out tyres but was not looking for anything too extreme.
    Like the idea of having dedicated wheels so I can travel back to Aberdeen and not have to worry about ripping up tyres on track.
    My tyres came good after the drive back home but took me a long time to clean my wheels of brake dust and rubber
    Got some video of you after passing me for a few laps, couldn't keep up on the straight..........Looking for RS2 turbo now!
    Will have to get it uploaded once I get home.
    cheers
    Steve
    Yup track wheels/tyres would be nice, I appear to have stuff burnt into my wheels, they are minging.
    Video would be great, thanks.
    Turbo envy, am am looking at an RS2 billet now
  • andy10v
    replied
    Most track day organisers stipulate a full cage is required if you are running slicks.
    Plus they will destroy all your suspension bushes etc real fast. Track day tyres are the best option
    Interesting, I did not know that.
    Yeah, the suspension is too soft with the current amount of grip, slicks would just bottom it out. Plus brutal on the rest of the car as you say.
    Also the engine oil control cant deal with the current grip level, and I know people have problems on slicks with oil pressure.
    I am leaning towards A048s just now (with some pikey suspension stiffening).
