I suspect the misalignment of the belt must have caused a wear on the clip and broke it. At least that's good news in a way as this pump may still be easily refurbished. Can you do it?
Audi 80 Avant
They are easy to rebuild, you need a press to get the pulley boss off the shaft - or a hydraulic gear puller. A normally puller will not do it unless it is a beast (I put about 5 tons on mine to get it off the shaft
There is no bearing for the shaft, it runs in the housing so that might be worn, plus the internals might be damaged - you'll need to check. If there is any dmage or wear, may as well throw it away and get another pump, they are very common across B4/B5 platform.
Make sure you use a genuine ZF seal kit or the shaft seal will leak.
Imola B6 S4 AvantComment
Ah so it was the shaft coming out of the pump, hopefully you can take the pump apart and fit a new circlip!Comment
Looks good
I missed your post above. I'm happy to have a look at the pump, I wouldn't want to promise a refurb as it sounds like its had a hard time!
The rebuild kits are only about ÂŁ15
I gave the pump to have it rebuilt. Indeed that was what had broken inside and hopefully now I have a spare. We also did your trick with the water pump. ABY pump and ADU wheel bearing.
Car feels very well planted in the front now and I had the tracking done locally so everything is well.
I'm a bit disappointed with the result of the 3 inch cat back though.
One the shop used mild steel for welding and used spray paint to avoid rust!!! Who in their right full mind do that in the UK. In Greece it's fine. We never have rain or snow to need salt on the road. Here it will rot in months.
Secondly the rear resonator is tiny and the noise between 2200 to 3200 rpm is so loud that it's unbearable to drive in cruising speeds in a decent speed. You have to constantly be above 3200rpm and use 5th gear or use earplugs.
It's giving me a headache so I don't even want to think what the wife and children will have to endure. + earplugs for me once I hear the rant.!!!
So I'm having the rear and maybe the middle resonator replaced locally with bigger ones in hope to cure the problem.Comment
What! I'd be taking it back if I were you, while they are cutting it apart and welding it with the correct consumables, they can replace the rear silencer
1976 RD250E / 350LC cafe racerComment
