Audi 80 Avant
    Glad I got one when I did for mine
    Was pretty cheap from the dealer a couple years back
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      #992
      Yes. Cheapest alternative now is audi tradition for 102€+shipping for one of the wood trims. Possibly the plastic may come in the future.
      I have one already trimmed in carbon. Need to see how I am going to use this one for my project!
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        #993
        Cleaning.
        All looks good and working.
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          #994
          Fuel level indicator 85€ from audi tradition... I shouldn't complain as little things like this once obsolete then it's very difficult to find solutions to...
          • rxl
            • 1913
            That's cheap
            Gesendet von meinem GT-I9505 mit Tapatalk
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              #996
              Got the roof channels delivered off a tdi so now I can say I have everything for a full restoration.
              Interior alcantara in case something needs retrimming and leather can be bought at any shop,
              Exterior I have all necessary trims, replacement front screen as some elements have been damaged and the heating doesn't work well, underbody will be inspected and coveted fully with sealant.
              Suspension will be overhauled with SS items for height adjustment new springs from Faulkner and standard Bilston shocks. I am very pleased with this setup.
              Control arms will be stripped and repainted. Front subframe is already galvanised and rear is ready to go in with fresh set of mounts and rear poly bushes.
              I will be changing the catalysts before the car goes back to Greece but I think the current ones have meat in them still and they will be for sale. They are 200 cell BN pipes.
              A full respray will be scheduled with engine and gearbox out and as the engine is in full working order I won't be touching it yet. It has had a belts change only about 3000kms and it's going strong.
              I will be also replacing the interior heater core as I think mine is blocked and heater doesn't seem to work.
              After all this work and once in tip top condition I am considering putting it up for sale. All parts are here and a huge amount of others that have been obsolete.
              • gavs20v
                • Sep 2004
                • 3057
                Up for sale ? I thought they'd bury you in this . What do you fancy next ?
                S2 Cabriolet.........
                • A80Avant
                  • Sep 2005
                  • 10873
                  • Country: Greece
                  #998
                  They might as I'm not going to let her go cheap!!! Haha
                  If it ever sales probably something cheap that runs on water or something. I would use some funds for house/work etc...
                  • A80Avant
                    • Sep 2005
                    • 10873
                    • Country: Greece
                    #999
                    New shoes and expecting today a complete set of discs pads and shims for the brakes. Those will be needed in a year or so but may as well stock them now.
                    Went with dunlop maxx st this time 225/40/18 with rim protection.
                    • A80Avant
                      • Sep 2005
                      • 10873
                      • Country: Greece
                      #1000
                      The old lady still has it.
                      Red/blue lines are from 2014
                      Yellow/green today!
                      Hey the 1000# post as well!!
                      Perhaps the delay in boost/torque could be due to wear and compression drop?
                      Having said that I do have slightly reduced timing on 2 and 3 cyl now
                      • Thuppu
                        • 4115
                        Why does the dyno graph end at 6500rpm? The power curve seems still to rise. Do you have exact same cam setup? Adjustable gears?
                        • A80Avant
                          • Sep 2005
                          • 10873
                          • Country: Greece
                          #1002
                          The way the graph is produced sometimes the end measurement may pull the graph up.
                          Engine is the same. Only change is reduced timing on 2 and 3 cyl and 3 inch cat back vs 2.75inch.
                          Finally my turbo is using the 0.63ar and does not produce any more power above 6500 to 6800rpm which is why I tend to drop the boos rapidly. I could have gone to 7000 but I was running out of road
                          • A80Avant
                            • Sep 2005
                            • 10873
                            • Country: Greece
                            #1003
                            New cat 200 cell fitted.
                            One of the old ones had already become detached from the tube so unfortunately I only have one available.
                            Not sure if anyone is in need of one. I think it's the left hand side which is still ok.
                            Otherwise if anyone wants a pair of tubing ready made to fit oem system and clear the metal elements to fit let me know by pm. I'm happy to let them go cheap.
                            • jade
                              • Jan 2005
                              • 1811
                              #1004
                              [QUOTE=A80Avant;910982]Got the roof channels delivered off a tdi
                              Hi Vas
                              So they were off a car being broken ? I have been looking for one RHS
                              What spring rate are you run on the back ?
                              RS 2 580HP
                              • A80Avant
                                • Sep 2005
                                • 10873
                                • Country: Greece
                                #1005
                                Yes. They were off a tdi being broken for parts.
                                Spring rate for rear if I remember correctly was 315 lbs but I'm not sure. I think I had posted everything on here.
                                When I go back in Greece I'll check as they do write it on the springs
