My S2 coupe
  • JP
    • 1858
    Straight fuel lines eho cares so long they don't leak
    UrS6 Stroker + HTA3586 =
    • TimE-J
      • Jul 2009
      • 1292
      Hopefully they'll be fine, going to pressurise them up in the next few weeks to make sure before I re under seal the underside.
      Finished painting the gearbox, mounts and spacer plate this evening.
      Also cleaned the old grease out of the CV joints but found that 1 is worn and turns out that its the same inner joint that goes with the shaft that is rotten so I'm on the look out for a complete O/S/R shaft now!
      96 S2 aby Coupe. Rebuild Project
      96 mk3 golf tdi daily.
      • PRY4SNO
        • 767
        Just read thru from page one, stellar effort on refurbishing your S2.
        I appreciate the attention to detail and, of course, all the photos. Keep the updates coming!
        2013 Touareg TDI /// #farmenwagen
        • BorisShakhov
          • Feb 2009
          • 224
          • Country: Russian Federation
          #199
          Done nicely
          I`am planing to do the same on the next week.
          Can I remove the gearbox without the engine removing?
          Can an engine fall down when a gearbox removed? How should I hold it on its place?
          • TimE-J
            • Jul 2009
            • 1292
            I'm sure you can remove the gearbox without removing the engine but tbh I have never done it so I couldn't confirm that.
            Haven't done much over the long weekend due to the weather and a local event that meant the normal 20 minute drive to my unit actually took over 2 hours so only went when the traffic was minimal.
            Started off by painting a few more bits like the rear diff mounts and steering assembly
            Started to paint the rear diff too, will try and finish this off over the next few nights.
            Also built up the front steering arms with the adjuster kit and derlin bushes supplied by Bambridge!!
            Its a shame about the pitting on one of the arms but the rust was bad before I gave it to the powder coaters.
            • TimE-J
              • Jul 2009
              • 1292
              Finished off painting the diff this evening and while I was waiting for that to dry enough so it could be moved I decided to remove the rack and give it a paint as well.
              Not long now until I can start bolting things back together.!!
                If I was you mate, I'd take those apart and grease them up or they'll seize up pretty quick
                Looking good dude, looking forward to seeing it all come together now, you must be pretty excited about driving it again!
                • TimE-J
                  • Jul 2009
                  • 1292
                  Thanks for the heads up, I'll hopefully grease EVERYTHING before it goes back together its just I cant help but put stuff together to see what it will look like. Plus it stops me loosing things in boxes and bags. I have honestly forgotten what its like to drive but I'm sure its better than driving the mk3 golf I have at the moment!
                  • marathontom
                    • Jan 2011
                    • 232
                    Looking great!
                    Before building up my trackrods I got an old bike inner tube and cut a section out n slid it down the track rod, built up the ball joint with greased up adjusters and slid the inner tube back over the adjusters and zip tied either end kinda like a cv boot, done a couple of winters and I've not had any trouble with them seizing
                    Just out of interest, what paint are you using on your gerarbox n rack? Looks a nice finish
                    • TimE-J
                      • Jul 2009
                      • 1292
                      The silver paint is this BBQ paint.
                      Although it is cheaper to get off ebay.
                      The black paint on the box is left over engine enamel.
                        Originally posted by marathontom
                        Looking great!
                        I will be doing that on mine next time the tracking needs doing as they always seize up no matter how well greased they are
                        • TimE-J
                          • Jul 2009
                          • 1292
                          More parts arrived and fitted!
                          Firstly a massive thank you too quattrostyle for sending out my new Meyle HD top mounts so quickly!
                          Finished painting the rack and fitted the new rack gaiter from TPS. When trying to refit the banjo bolts one bolt with the one way valve cracked around the tread so I'll be having to order a new pair of bolts from TPS tomorrow.
                          Started to assemble the rear diff. I decided not to change the seals in the end, I made sure the breather was unblocked and that everything was clean and in good order. If the diff seals do leak then I will remove the diff again and change the seals along with a TORSEN if I can find one at the time.
                          More to come.
                          • AndyP
                            • 6049
                            Once you've got the tracking set, wrap up the adjusters with this stuff
                            http://www.ebay.co.uk/itm/DENSO-TAPE...item5d2a9a2eab
                            It works brilliantly, keeps out all the water and salt off the roads so the adjusters are like new when you come to use them again.
                            • quattrostyle
                              • Oct 2006
                              • 6229
                              Looking good Tim
                                Good tip Andy, I've just ordered some
