I´m asking about the noise but you wrote it was injectors. You use solid lifters or hydraulic?
UrS4 2.2T Sedan project
Not much has happend with the car. But i have bought some more parts for it at least.. Stumbled over a 034-motorsport short shift kit that i was forced to buy.. I'm happy with the shifter as it is, but with this kit it may be even better i hope. Does any one here have some experience with this kit?
filedata/fetch?id=2015489&d=1518128818&type=thumbYou do not have permission to view this gallery.
This gallery has 1 photos.
Originally posted by s0_big View PostNew flywheel and clutch disc
Hello! Yesterday i received my new alu-flywheel and clutch disc.
Mounted it to the car today also with a new clutch cylinder because the old one was leaking i think. So tomorrow i will sure know if this works fine with the Maxxecu. I hope so A shame to hide these nice pieces but atleast i know that they are there
Got the same flywheel/clutch setup but struggling to get the clutch to stiffen up. We moved from the original dual mass... Any tricks i should know about? Great build btw, and a big help for our project!
Originally posted by amarider View Post
Hi
Got the same flywheel/clutch setup but struggling to get the clutch to stiffen up. We moved from the original dual mass... Any tricks i should know about? Great build btw, and a big help for our project!Last edited by s0_big; 26 February 2018, 22:08.
Today i got my thumb out and installed a fuel pressure sensor. With the help of forum member "Jonas_R" i got a adapter for the original fuel lines to put a sensor to my Maxxecu in. I painted sensor and adapter black to make it blend in better with the other stuff. Big thanks to Jonas for making the adapter i needed for so long as 034motorsport didin't make them any more.
Fuel pressure sensor installed and wired:
20180304_124726.jpg I also got a the ac/fan belt cover and coil/connector cover wrapped in carbon fibre folie. Looks pretty nice i think:
- 1 like
