Titanium Grey S4 Avant
Got the engine to crank when I try to start it, but it still doesn't run. Checked the spark plugs and they were dry, so injectors ain't opening. Because my laptop is being **** I can't connect it to the car for some ****ing reason even though I could on my other car, I thought I'll take out the G28 sensor and while trying to take it out I ****ing broke it, so now I have a metal tube in a hole I cant get out
Can't take the whole bracket off becuse them bolts seem to be welded in there + access is complete ****.
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDIComment
And breathe!!
Immobilisers usually break 2 circuits. One from the ignition switch and often the fuel pump. We're there any wires from the immob going off anywhere else? Maybe in the direction of the loom near the ECU?Comment
Try tapping the sensor bracket bolts with a hammer and drift, carefully so as not to break anything
then try again with socket or spanner
Laptop, maybe the OBD Diagnostic fuse has blown?Comment
G4 and G28 Maintenance
I am really starting to doubt your capabilities with a wrench and/or patience performing a task. Obviously you forced things without first trying some anti-rust/corrosion sprays down there.
Access to the G4 and G28 on an AAN is not crap (far better than the knock sensors - at least you can see the G4 and G28). BTW most G28 error codes are false and the G28 is almost never a suspect in a non-starting situation. Your issue is likely down to the after-market immobilizer.
G4 and G28 Maintenance:
If access is crap how did I take this photo?
I can't see any wires from the immobilizer, seems like they all been already taken care of. I can't see any loose wires apart from the green/brown one. Ignition switch plug seems untouched, everything is original. Ignition is giving 12v signal for the starter motor, but starter motor isn't getting it.Laptop, maybe the OBD Diagnostic fuse has blown?
Have to do something, gotto take a break though
Laptop wise, it connects ok, shows that it's connected, but when I go onto engine it thinks for a bit and just says no response from the controller.'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
ECU is not powered upComment
C4 UrS Starter Circuit Wiring and Relays
Some UrS starter circuit info:
General:
The UrS4/S6 Manual Trans OE Starter Interlock Relay:
Sorry to semi-hijack the thread, but I cannot read the engine module via VCDS on my S6 at the moment, even when the engine is running. All other modules (ABS, HVAC etc) connect without a problem. Will be interested to see if this throws up any answers for me
Callout for the Above ECU Fuse Panel Fuses - UrS4 and UrS6 differences
Yes. The 5 Amp spade fuse in the red holder above the ECU
Callout for the Above ECU Fuse Panel Fuses - UrS4 and UrS6 differences:
